Question about Olympus FE-370 Digital Camera
Dropped the camera, picture is now blurry and the lens and shutter makes a noise when turning camera on and off.
  • 619 Answers
SOURCE: can't zoom!
dislocation of motor drive gear / need to fix by near camera technician.
Posted on Jan 04, 2008
SOURCE: Focus Trouble
same here - 1 month old... camera never dropped at any point. thankfully there's a warranty!! just about to send it back to olympus for repair but after repair if it does it again i'm going to return it as not fit for purpose - i really don't fancy the repair bill if it hapens again when out of warranty!
MaFt, UK
Posted on Jul 03, 2008
SOURCE: Olympus FE-280
I'm dealing with the same issue. Most likely there is fine sand or dirt jammed in the lens. Do not try to clean it with any liquid cleaners. Take it to a shop to try to get it out.
Posted on Aug 03, 2008
  • 919 Answers
SOURCE: Camera will not turn on.
You should probably call Olympus Customer Service to discuss having the camera sent for repair. Their number is 800-622-6372 option 2 and then option 3.
Posted on Dec 10, 2008
SOURCE: When I turn the camera on it makes a few noises then shut off
i called the company (1-888-553-4448) olympusamerica.com and they told me to send it in and they will repair it for 70.95 plus a 6months warranty because i cant find my reciept. they also said what eva is wrong with it they will be able to repair it, but if u have ur warranty u can send it to them it wont cost u anything because u have ur reciept.
Posted on Mar 23, 2009
HORIZONTAL STRIPES ON PICTURE
Hi!
Turn on the camera
Pull the lens at maximum zoom
Turn off the flash!!!!!!!!!!!!!!!!!!!!!
Shoot the picture - look into the lens.
If no motion picture shutters in the lens:
1. Faulty flex cable shutter
2. Faulty valve solenoids
etc.
Requires repair of the shutter assembly in the lens
If you saw the shutter and blurry pictures as paint - matrix defective - Replace the camera matrix.
Dec 08, 2013 | FUJIFILM Finepix S2100HD Digital Camera
Blurry pictures
A common problem is a finger print on the lens. If needed, clean the lens with a microfiber lens cloth. Commonly available with spectacle cleaning kit. Did you drop it? Are you actuating the shutter by "squeezing" the button and not pushing on it, moving camera around? Try using a shaky hand setting, often indicated with a hand icon and wavy lines, indicating movement.
May 04, 2013 | Kodak EasyShare M532 Digital Camera
Nikon D60x Blurry night pictures
Try switching to Shutter Prority (S) with a fast shutter speed.If the light is not so good, up the iso to 800 to gain that faster shutter speed..
You do not say the lens in use ? if VR, make sure its switched on or use a tripod.
Hope this helps
Jun 22, 2009 | Nikon DSLR D60X D60 Body DSLR 10.2M pix...
Blurry pictures....
reset the camera and try taking pictures using by soft pressing the shutter instead of a hard press... on digital cameras, hard fast pressing will cause the picture quality to be not as good
Jul 31, 2008 | Olympus FE-230 Digital Camera
Which lens
Hey caturner7,
If you have a large family and you are having a difficult time fitting everyone in the frame then a wide angle lens might be exactly what you need, but this will probably not make your images any sharper. The most common cause of blurry images is the camera is moving during exposure. Even the slightest camera shake can cause blurry images. There are multiple solutions to this, first make sure the shutter speed is high enough, then make sure the ISO is set to about 400, and then make sure the flash is on. Another cause of this could be that the camera is not achieving focus so make sure you are pressing the shutter button down halfway so the camera can achieve focus before you take the picture. A slightly telephoto lens usually produces the most pleasing portraits. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 03, 2008 | Cameras
Fuzzy images
Hey jjbeanwink,
This is a very nice lens, and is unlikely that your blurry images are caused by the lens. The most common cause of blurry pictures is that the shutter speed is set to low. A general rule would be your shutter speed should be at least 1/60th of a second while handholding the camera. The bigger the lens, and the higher the magnification of the subject you are using the faster the shutter speed you should use. If camera shake is the cause of your blurry pictures you could also try using a tripod. Another common cause of blurry images is subject movement, and one solution would also be setting a faster shutter speed. Another solution is using the flash to stop the action instead of the shutter speed. Of course manufacturers do occasionally make a bad product and that is why there are manufacturers’ warranties. If you just purchased this lens you could have an authorized service technician look at the lens and see if there is anything wrong with it. I these suggestions help!
Sincerely,
Allan
Go Ahead. Use Us.
May 12, 2008 | Canon 24-70mm f/2.8 Lens
Blurry pictures!! help!
If it's making noise when turned on you are experiencing trouble with the lens. If you send it into repairs they can fix that. Give them a call at 800-706-2534 option 2.
Apr 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Buzzing sound
the problem is with lens.this sometimes happens if cam becomes victim with water.
there is some buzzing noise when the shutter of lens gets opened or closed.
please clean the lens with the solution once.then you can make out of blurs.
Apr 04, 2008 | Samsung Digimax S630 Digital Camera
Blurry Pictures!!!:(
This is something that will probably have to be sent in to be fixed. First try resetting your camera. In REC mode press menu go to setup tab go up to reset press right arrow highlight reset & press set. If that doesn't work send it in to repairs.
Jul 10, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Olympus FE-370 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
