Question about Samsung CLP 300 Laser Printer
Despite replacing my waste toner compartment, the printer will not work with the red light permanently on.
  • nealuren Sep 28, 2009
    Sorry
    I'm afraid that his had made no difference.
    Neal Uren
  • 10,515 Answers
There is a fuse that is in the cartridge and it is blown, If you need, get a small tube-type fuse in a 100mA, 250V setting,If you hold the cartridge like you are going to put it in, the far, left edge of the cartridge, that first goes in, you will see a phillips screw head. There is a small "claw" there that holds the fuse in place. It will probably blow out again in about 100 or so sheets.
Check and if you find it OK, then there are some other parts on this machine that are not serviceable by the user, the corona wire and the heater, these maybe the problem.
Short Precise Solution - In most cases, If you see a red light there is a possibility that the internal circuit might have got damaged. This would require a professional to fix the problem. So, the best thing to do would be to call the technical support of the company, who would help in fixing the damaged internal circuit.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 29, 2009
  • 4,281 Answers
First pull ink cartrige from printer.
Then check for paper jam.
Clean dust and ink powder from its position on printer.
Then refix ink cartridge then check.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 26, 2009
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
When I print a page black lines appear on the page making. Its like the toner is leaking or something. I don't know how to fix this issue. I've cleaned the inside of the printer several times and...
The toner is leaking. The toner cartridge has two compartments, one for new toner & another for waste toner. When the waste toner compartment is becoming full to its capacity it starts throwing extra toner outside of it. That is what is called toner leaking. If you can empty the contents of the waste toner compartment, your problem will be solved. One more thing if wiping blade for waste toner is worn out, it also leads to toner leaking.
Aug 02, 2011 | Samsung ML 2151N Laser Printer
Hl3040cn prints a black stripe down the page despite the drum being cleaned as advised by Brother.Peter
Hi
3 issues might be the problem.
1. The toner waste compartment is full. You need to clean the toner waste compartment located in the cartridge itself.
2. Roller drum inside the cartridge have lines normally starts on both ends of the drum. This due to bulky printing. Check and replace this parts inside the toner cartridge. Manual cleaning is not advisable because the result will still the same. If you have only toner cartridge, use the roller drum and replace in place of it.
3. Faulty Toner Cartridge that cause leaking the toner powder. If you purchase remanufactured toner cartridge or you refill the toner cartridge. It tends to worn out the parts. Normally starts as roller drum and follows with the other parts. Replace new original Toner Cartridge. When you refill the toner cartridge, you need to clean the waste compartment as well as it will later be full and overflow.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 15, 2011 | Brother HL3040CN Laser Printer
Red light stays on and printer wont work
Check the waste toner bottle on the left side. If that is full, you will get red light. Just empty it if is full of waste toner. Re-use the waste toner bottle.
Mar 09, 2011 | Samsung CLP-300N Laser Printer
Red light on suggesting replacement of parts
get geniune toners and replace waste toner bin.
Jul 05, 2009 | Samsung CLP 300 Laser Printer
Alarm light is RED and data light is AMBER - both are on permanently
This means toner is empty. This condition was probably preceded by a period of "toner low" indications, data- and alarm LEDs blinking shortly every fifth second or so (maybe you never noticed that). Replace toner cassette and it should work normally.
Jun 02, 2009 | Brother HL 1440 Laser Printer
Samsung clp 300 ser red status light stay;s on cartrigde light
The waste dispenser (next to the toner cartridges) probably needs to be emptied out.  That's what always sets off the red light for me.
Nov 14, 2008 | Samsung CLP 300 Laser Printer
My brother 2700 printer is asking for the waste toner pack to be replaced.
If this is a color printer, then there is a compartment where you will find the waste toner bottle. You can empty it out or vaccum it out. Then replace it.
Jun 14, 2008 | Brother Office Equipment & Supplies
Samsung CLP 300 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
