Question about Kenmore 22.0 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Ice developing in bottom of freezer and inside bottom of door
I tried to replace the seal, but couldn't get it to line up properly. The repairman order the seal and said it would fit. Is there special instruction to prepare a seal for instalation? Could the ice build up be from some other reason?
  • 725 Answers
Check the defrost drain... you can remove the back panel and check the drain if ice over the drain you will need to clear it with HOT water... let me know fi it helps
Posted on Sep 26, 2009
I have a samsung refrigirator side by side with a bottom freezer door. It is leaking from the bottom of the right side of the freezer right of the free
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then
Jul 15, 2014 | Samsung Refrigerators
Why is water and ice forming on bottom of my refrigerator?
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Jun 11, 2014 | Samsung RF265AA Bottom Freezer French Door...
The freezer door is not sealing properly and seems to be off the track.
the spare seals are available,if the seals are not sealing,then may be its got worn out/ over stretched so it has to be replaced.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | LG LFX25971ST Bottom Freezer French Door...
The fridge and the bottom freezer are working fine. However there is a lot of ice developing at the bottom of the (bottom) freezer. Although we recently de-frosted the freezer and removed the ice (water),...
there is only 2 things if you dont have an ice maker inside your door is not sealing all the way around or the drain is cloged with ice and everytime the ref goes into defrost the water leak into the fzr unplug for 2 days that shoud fix it
May 30, 2010 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Ice forms around fan and makes a loud humming noise
It's probablly caused by air leakage through the ice room fan electrical connection inside the freezer. Behind the back wall inside the freezer, the icd fan is the fan that blows air up to the in-door icemaker. The plug on that, into a molded plug on the back of the feezer compartment, is a red plastic part with three wires in it. Try filling in around the wires and the red plastic with a bit of silicone. (if you replace the ice room fan, the new plug comes with a rubber filler which seals this spot). (PS. Next time, avoid Sears)
Mar 31, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
My frost free freezer is icing up on the bottom of the freezer. Occasionally find water on floor No
If the ice is clear and frozen on the floor of the freezer the defrost drain line may be plugged causing the water to over flow the
drain trough and leak into the bottom frezer compartment.
This will require a service tech. to remove the rear panel inside the freezer and find the reason for the blockage of the drain line.
ie....
Mold or slime in drain line
Debirs covering the drain inlet hole
Out of spec defrost heater.
If the ice is fluffly like snow then the freezer door may not be sealing properaly.
With the freezer door closed check the door gasket all the way around the freezer door.
If a gap is seen on one side the freezer door may be misaligned.
To realign freezer door remove all ice with a hair dryer.
Soak up all moisture on the metal rails and inside the freezer.
Pull freezer door all the way out unitll it stops serveral times.
This may realign the freezer door.
If not the door slide rails,Track or Roller gears may need to be replaced.
Jan 15, 2010 | LG Refrigerators
My F20NAC builds up a huge amount of ice in the bottom and freezes in the bottom basket in ice. I have to melt it with a heat gun to get it out. today I melted 2" of ice. What's wrong?
The problem is most likely the thermostat. When it goes bad it prevents the freezer from regulating the temperature properly. You should get a repairman to check it out as its not an easy self fix. Also make sure the gaskets around the door are sealing properly. If there is a leak between the door and the machine itself that could also cause ice buildup.
Dec 12, 2009 | Refrigerators
Our N369B fridge freezer has a large amount of ice clinging to the upper back of the fridge how do we stop this happening?
Your freezer door is not closing properly. if it is not on wheels then make sure the bottom nut that also holds the front wheels or slider in place is tight. Also maybe have the seals replaced and check door alignment on both doors. You will of course have to defrost the freezer.
Oct 27, 2009 | Fisher and Paykel Active Smart E522B...
Water is leaking from the bottom in the front left side of side by side maytag. water line is ok not leaking. can't see where it is coming from.
the water for the dispenser (ice/water dispenser in the freezer door) comes from under the frige then up thru the bottom hinge of the freezer door .. it then goes inside the door up to the dispenser .. its a plastic hose and it has to twist near the hinge each time the door is opened .. thats where it usually breaks or develops a pin hole leak .. you can replace the whole hose or just the damaged section if that easier ... since the bottom freezer.hinge where that hose comes up thru, is at the position of your leak then i suspect thats your trouble ... ..also check the condensate pan to make sure its not full .. thats a flat pan under the fridge ..you can usually get acess to it by removing the front kick panel at the bottom of the frige .. if thats full then look for a door seal leak (damaged rubber seal) ... a broken seal or open door will allow moisture to condense inside the machine ..that runs down into the condensate pan where it normally evaporates .. but a problem (like open door) will fill it up to overflow in time ....
Aug 05, 2009 | Maytag Refrigerators
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Refrigerators Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
