Question about Home Theater Systems
Ampli toshiba je cherche shema pour amplificateur toshiba 4 Channel model SB514
0 characters
1 Points
How to play raido
u didn't mentioned the model number of ur Coy DVD, any way do the following
first of all connect the AM and FM antenna to ur dvd player. ( located in the back side)
take the remote and do the following
1 .press the AM/ FM button. make selection u need AM or FM ( if u want to turn channels on AM select AM and got next step, after that select FM and do the same for turning FM channels)
2. press the MO /ST button to select stereo.
3. press the AUTO button to auto tune channels available
4.what till all channels memorized
now ur radio is tuned. u can directly select the station using the numeric keys ( for eg:- to go to channel 2, u should press 0 and then 2, if u want o go to channel 14, press 1 and then 4.
u can also select channels by pressing the RADIO plus and minus button .
when u want to listen radio press AM/ FM button and select ur desired channel.
Dec 17, 2010 | Coby 5.1 Channel DVD Player with Home...
I turn on my system it says check spkr and turns off
Have the soldering remaked on the audio power ampli.
Spider Guy
Mar 15, 2010 | RCA RT2250 System
I have a older model RCA tv (1999 ?), and I am trying to connect a Toshiba vcr/dvd combo to it. Plugged the red, white, yellow cables to both, no sound or picture. What did I do wrong? connected to cable.
you need to switch the input. there should be a button on your remote on which has the symbol "quadrat with a arrow" on it. on older tv's you have to switch to channel zero or lower or press the AV-Button.
Jul 27, 2009 | Home Theater Systems
My VCR not recording after the switch to digital tv signal
The answer to this question can get a little complicated. Lets tackle it in two parts. First the last part; the part about picking up channels as decimals. With analog TV transmission, it took the full television broadcast channel to transmit one standard definition TV program. The newer digital transmission system uses some advanced video compression and audio compression technology to reduce the data needed to transmit the pictures and sound which allows the same bandwidth to deliver either High Definition Television programming or MULTIPLE channels of Standard Definition programs. So in your example above, you use to watch one channel of programming on TV channel 4, but now the TV station can broadcast multiple channels of programming on channel 4, sot they delineate the programs with a decimal point. So 4.1 it the first program on TV channel 4, 4.2 it the second program on TV channel 4..... Well, I hope you get the idea.
Now for the hard part of your question. I believe that before the transition, even with your new digital TV, you were still enjoying the analog broadcasts from your stations. Your VCR picked them up and recorded them and your digital TV could tune them in and you watched as you had always done in the past. After the transition you noticed that your VCR could not record anymore and your digital TV had discovered the digital channels that replace the analog channels. To remedy this situation, your VCR will need the aid of a DTV converter box to tune channels, and you may have to reconfigure the way your TV and VCR are connected. The best resource that I can give your for the reconnecting is the website Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Scroll down to the Normal 0 false false false MicrosoftInternetExplorer4 section about “Set-up #2: Watch One Channel while Recording a Different Channel”.
Hope this helps
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
Tried the RF Out setting and now Ican't reset it or even get the STB to respond to set up or anything.
If you changed the RF out channel setting on the DTV converter and now can't see the output of the converter try changing the channel on the TV set. THe DTV converter boxes are designed to output either RF channel 3 or RF channel 4. If you were on channel 3 and changed the converter output to channel 4, you will have to change the TV channel to channel 4 to see it again.
Hope this helps.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Home Theater Systems
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Jan 16, 2008 | LG LH-D6230 System
Finding a remont
zasto je poceo da mi dimi motor? rekao bih da su mu karike, ali on ne dimi uvek,znaci,jedan dan dimi a drugi dam je ok, kada trokira ,znaci , on i dimi , a kada radi motor kako treba onda nema dima?????????? kawasaki zx6r 1996 godiste.
Dec 05, 2007 | Home Theater Systems
Home Theater Systems Logo
Top Home Theater Systems Experts
Gyula Lacz
Are you a Home Theater System Expert? Answer questions, earn points and help others
