Question about Dryers
Model LeA80AW will not start. It is connected with a 3 prong 30 amp cord, don't know if its connected right. It looks like there is electricity running to it, but it does not start.
    President:
  • 1,776 Answers
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Posted on Sep 26, 2009
Manuals free
Your question was worded poorly and it's difficult to understand what you are asking. As a guess, if you are looking for a 30-amp adaptor cord set, perhpas this will work:
Conntek 20601 25 Foot 10 4 30 Amp 125 250 Volt 4 Prong L14 30 Transfer...
If it's a 3-prong adaptor:
Camco 55333 30 AMP 3 Prong Generator Adapter
Or a 15 to 20 adaptor:
Coleman Cable 09020 12 3 9 Inch Generator Cord Adapter 5 15P to L5 20R
Aug 27, 2014 | Electrical Supplies
What a 240 plug look like
A dryer cord is smaller than a range cord and it also has a curve in the ground prong so that their would not be a chance to use the 30 amp cord with the 50 amp range. Dryer cords come in 2 differing styles 3 prong and 4 prong. typical dryer cords look like this:
Feb 13, 2013 | KitchenAid Dryers
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
How do i change the cord?
Hi there, My question for you is, I'm going to assume this an 220 volt / 30 amp electric dryer - which is most common. Therefore, it sounds to me like you have an existing receptacle which has a 4-prong design. And, that you have a dryer with the electrical power cord already attached to it. If this is correct, then you would just need to replace the receptacle from a 4-prong, to a 3-prong. What you would need to do first is check the amperage on the existing receptacle. You want 30 amps, which is standard for most all electric dryers. If so, great! If not, it's most likely a higher amperage - which is fine. Then you'd have to go to your nearest appliance store (home depot, Lowe's, etc.) and pick up a 220 volt / 30 amp 3-pronged receptacle. Then, to replace it - first turn OFF the 30 amp. 2-pole circuit breaker. It's most likely the only one you have in your electrical panel. If there's two, then get a little inductance/voltage tester when purchasing your receptacle - to check for power. These are worth their weight in gold. So not to confuse (which I hope you're hangin' with me still..:) you any further. Once you've turned power OFF, and confirmed it. Remove the cover and receptacle (leaving the wires attached). Then, remove the ground (green) wire from the 4-prong recept. and put that into the 3-prong recept. Then, take the black wire off - and add it to the other too. Then you should have a red (but sometimes another black) wire. Do the same as you just did with the black. Now, the remaining wire (which is most likely a neutral/white) - you can cap this with a wirenut, or tape it good with electrical tape - and tuck this into the back of the box. Now make sure you've tightened and secured your connections...then attach the receptacle to the cover (see a note below on this cover) if applicable. Otherwise, you'll need to purchase this also. Actually, regarding that note I mentioned. You might want to pick a cover up when you purchase your receptacle, or at least ask the clerk. Off hand, I don't remember if they are compatible, or not? Anyway, after you're finished securing and wiring your receptacle - now you can go turn ON your circuit breaker. If it holds, great! If not, recheck your connections - and then contact me. I'll walk you through this. However, I believe you'll do fine. Anyway, Good Luck and I hope this helps! - Jim
May 24, 2010 | Estate TEDX640JQ Electric Dryer
I am replacing a 4 prong cord which is red, white, black, green with a 3 prong all black cord. My stove is a Maytag which was originally wired with a 4 prong pigtail for use in a trailer. I want to replace...
Okay, without knowing everything I would need to know; here's what I propose you do. First of all, are you exchanging the same wire size cord (eg. #12 stranded wire for 20 amp, and #10 for 30 amp, #8 wire for 40 amp,  # 6 for 50 amp, and so on) for the same application (ie. 30 amp for dryer, and 50 amp for range, etc.) ?  Let's say you are, so what you want to do is take the 4 prong off (one by one), and write down the configuration and color, as you take off each wire. And then you're going to apply this to your 3-prong plug. So, without seeing the plug and its application - I'm going to explain to you how to wire this. First, put the black (hot leg) wire will go on one of the straight prongs - and the red (the other hot leg) wire will go on the other straight prong. Now cut the white wire down to about an inch, so it can fit into the plug when you're putting the cap back on. And remember to tape this white wire with electrical tape. This is for many reasons, but its basically for safety. Now, the remaining wire (green) goes to the right-angled prong - which is your ground wire. Now your wired for 240 volts, and depending on the size of the wire - your wire size shall be in accordance with the amperage that I explained earlier. Now make sure that your power is off at the panel before you plug this oven plug into the wall. Then, turn the breaker on, then off. If everything seems okay, plug the cord into the wall (with the oven off) - and then turn the breaker back on. Then proceed to turn your oven on from there, and then if everything checks out okay, then your good to go. Good Luck with this, and I hope this works out for you. If not, feel free to contact me again. - Jim
Apr 05, 2010 | Ovens
I need to replace the dryer cord which one would be the correct cord
The correct cord can be found at most appliance or building supply stores. look at the receptacle for the dryer. If it is 3 prong or 4 prong, that is the determining factor for what cord you need, The Dryer is rated 30 amps, 220 volts, That is the rating of the cord. BUT the cords will be labelled in the packaging. there are two that are similar, Dryers and ranges . you want the one labelled Dryer.
Jan 16, 2010 | Danby DCD5505W Electric Dryer
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
What type of power cord ( 3 or 4 prong) for an electric dryer
Hello markdraghi,
I assume ( but don't know) that you are replacing an existing dryer... That said, then you need to match the cord ( 3 prong or 4 prong) with what you currently have for a receptacle. A 3 prong uses two hot feeds ( red and black) and a Neutral ( white). A 4 prong uses the same as the 3 prong but also includes a Green wire for Ground. Get back to me if you need wiring details or if I have NOT answered your question. Hpe this helps.
Regards,
Rick
Jan 04, 2009 | GE DBSR453EBWW Electric Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
