Question about Craftsman Garden
After about an hour of running the mower suddenly runs rough and quits. If I give just a little choke it runs a little longer.
  • 437 Answers
Sounds like it is starving for either fuel or air. Check the air filter, spark plug and get some fresh fuel from the gas station. Try to put an additive in your fuel called "seafoam", you can find it at an automotive store.
It may need a professional to give it a good tune up.
Posted on Sep 26, 2009
Why is the engine running rough after a few minutes and the spark plug gets carbon on it?
Could be your choke is not shutting off like it should and some mowers the choke is on when you put the throttle wide open. Cut the speed back just a little and see if that helps.
Aug 01, 2015 | Garden
Engine only runs with choke on. Blue smoke comes out and engine runs rough or not at all
sounds like you have a bad Ring on the Piston or a blown head possibly. Blue smoke means Oil is getting into the combustion chamber. Full choke means you have to give this 'broken' engine a lot of gas to compensate for it's problem.
Do you change the oil at least once a year? Filthy oil or a lack of oil will kill an engine
Aug 06, 2012 | Yard Man Garden
My briggs and stratton mower runs rough but when I toggle choke on and off it runs better for awhile
have to use choke means fuel problem. Check your fuel cap vent, fuel filter. Fuel solenoid opening with key turn on. Remove hose from carb.and see fuel runs out.
Mar 10, 2012 | Craftsman Garden
Lawn Mower runs rough & dies has black sooty spark plugs
A good place to start would be to remove air cleaner assembly and give it a good wash and service and take a close look at choke assembly/lever to be sure it isn't sticking in on position, while trying to run it with air filter off..
Nov 25, 2011 | Mtd 22" Yard Machine Push Mower
Engine starts, runs for awhile and then inexplicitly quits. Starts up again and when it begins to quit, I push the primer button and it says running, but only for a little longer. When warm, it stays...
well you know you have a fuel starvation problem and it is not the filter. so begin by getting a rebuild kit for the carb, from a small engine repair shop, giving it a good soak in cleaner while it is in pieces. make sure all the passages are open and reassemble it. if you are not confident in your take apart and rebuild skills you can pay a shop to do it for you. i think your choke enrichment is doing OK, just like the primer, the basic keep it running supply is plugged.
May 16, 2011 | Garden
I start the motorcycle each morning with the choke and let it run for about 2 mins and back off the choke all the way and rev it a couple of times and it idles a little rough but stays idling. When reving...
1. When you rev it up, has it reached its normal operating temperature?
2. If you know how to then check your timing as it sounds like a little off at the moment. When did you have it adjusted last?
3.You can add some fuel cleaner when filling up again and run with it until the tank is low again.
God enough, then return a comment. Thanks
Nov 08, 2010 | Yamaha XJ 650 Motorcycles
My engine was working fine for about an hour, then started sputtering and finally quit. I re-started and it ran for about 10 min and the same thing happened. I tried again today and the same thing...
Check filter of course but also you might think of doing a carb cleaning also.Sounds like you might have something floating around in the carb, maybe even a little water in your fuel.If its running better in choke mode it's starving for fuel have carb checked and cleaned. Good luck
Nov 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere L120 appears to run out of gas
This is the most common problem with the L120 I'm told. The pin hole in the gas cap needs cleaning (top and underneath as well). I have replaced mine twice already and have only 140 hrs. on it. Starts right up after cleaning. (My symptoms were identical to yours)
Mar 22, 2009 | Briggs & Stratton Garden
My husqvarna GTH2448T has to be choked to run
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes.
Oct 06, 2008 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
83 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
