Question about Kenmore Washing Machines
I have a kenmore heavy duty, series 70,# 82872120.. It makes a humming noise and will not complete the rinse cycle or the spin cycle.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82872120
If it goes through the agitate cycle, the motor and transmission are probably OK.
If it goes through the initial drain / spin cycles after the first agitate cycle, the Lid Switch is also OK.
The humming could likely be the timer motor. Try to manually move the timer to the rinse cycle. If the washer responds, the problem points to the timer itself.
See the sub component section on the Sears site for the Console.
The "Alt" part numbers are Whirlpool parts that can likely be purchased from a variety of on line or local parts stores.
Posted on Sep 26, 2009
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore washer model 12502100 goes into rinse cycle fills with water turns then stops. won't drain just stops hear humming or buzzing noise.
Try to put it on rinse on another cycle, like normal, heavy duty or delicate. If it works, then your timer is probably bad. If it doesn't work then maybe the pump. Best of luck
Mar 21, 2010 | Washing Machines
Washer doesn't rinse well. Doesn't spin water out properly.
Ok.you need tro make sure that its pumping out okay...if not check the filter..then pump..
Feb 21, 2010 | Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Rinse cycle do not disengaged
does it drain?did you check the lid switch?
May 17, 2009 | Kenmore Washing Machines
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
210 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
