Question about Canon PIXMA iP90 Mobile Printer
Daughter dropped printer...not far from
Canon iP90 printer offline...daughter dropped printer...not far from floor...but now when go to print it says printer is offline...how do i fix this?
  • cpfan82371 Sep 26, 2009
    My daughter went to pick up printer off of floor and when it got about 3 inches or so from floor it slipped out of her hands and hit floor on side corner. I went to use it a few days after that and it said printer offline...i have tried unplugging it and then plugging it back in and it still says same thing.
  • Ryan  Ruch
    Ryan Ruch May 11, 2010
    Have you tried to unplug the printer power (for 1 minute) and plug it back in?
Soulvisitor
  • 1113 Answers
SOURCE: print head for canon ip90
yes
6d8b426.jpg http://www.softwareforless.com/findspecs.asp?partid=52912B
Posted on Dec 29, 2007
  • 76 Answers
SOURCE: Figuring how to install new print head in my Canon iP90 printer
when you open the top cover, the carriage unit will mvoe to the middle of the unit. Once it is there hold the inks and move a bit to the left so you can see a grey lever. then the printhead and the inks will come up together. remove inks and replace head.
This should work for you
Posted on Oct 20, 2008
  • 97 Answers
SOURCE: error 5100 canon ip90
You may try this to rest the 5100 error:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Posted on Dec 07, 2008
SOURCE: Canon Pixma ip90 printer
service error 5100
Posted on Jan 04, 2009
Joed911
  • 4338 Answers
SOURCE: Canon Pixma MP610 Won't print but will scan and/or copy
Check the properties again, Then try to print a test page.
If that does not work go to this link and download and install the printer drivers:
Just select your OS:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15604
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 29, 2009
Black is not printing after dropping my Canon ip90 printer. I changed the black cartridge. How can I fix this?
How long did you leave the printer before you tried to use it again after it failed? has the ink dried in the jet head?
There should be a ribbon that feeds the jet head which controls the head itself, has it come loose?
Dropping any electronic equipment onto a floor can break motors damage bearings and loosen cable connections. the cost of replacing parts generally outweighs the cost of replacement. It may be that the unit is not economically repairable.
Apr 15, 2015 | Canon PIXMA iP90 InkJet Printer
Error message that my IP90 Canon is offline.
Check that you haven't accidentally changed it setup to being off line, you will find this in the devices section of the control panel. If that doesn't work I suggest you re-install the printer software using the setup disk that should have come with the printer. Hope this helps.
Dec 30, 2012 | Canon PIXMA iP90 Mobile Printer
Hi. there is an alignment problem with my canon pixma ip90 printer. I haven't used it for years and finally decided to take it out. changed the ink cartridges, and the alignment problem started. Please...
Go to Control panel. Click on Printer and Faxes. Right click on your printer icon. Click on Properties on the drop don menu. In the properties click on Maintenance Tab. Click on print-head alignment on the drop down menu/tab. Check the printed page after the alignment is completed. If not OK carry it on again till you get the right print.
Aug 20, 2011 | Canon PIXMA iP90 InkJet Printer
Won't print-- says the printer is offline (everything is on and plugged in)--just had my hard drive rebooted--something must have gotten unclicked...help!
Find your printer in control panel. This varies with OS installed (which you did not mention).
1) Right click your printer name
2) Choose "Use printer online"
Try your print job again.
Dec 20, 2009 | Canon PIXMA iP90 Mobile Printer
CANNON IP 90 PRINTER PROB: ink try full. how do i clean it? i saw instructions on resetting codes. it will not print at all...HELP...Thank You!
How to Reset The Canon Pixma iP90 PrinterHere is the reset procedure for the Canon iP90 printer, which uses the BCI-15BK, BCI-115C and BCI-16C cartridges.
Just follow these step by step instructions, to reset the Canon Pixma iP90 printer
  1. Turn printer OFF.
  2. Press the RESUME button together with the POWER on button.
  3. While pressing POWER on button, RELEASE the RESUME button.
  4. Press RESUME button TWICE then release both buttons.
  5. The green LED indicator will start blinking, then stop.
  6. Wait until the Power LED lights are green, then press the RESUME button 4 times.
  7. Now press POWER button OFF.
  8. Turn printer ON again, your Canon iP90 printer should now respond normally.
  9. If you need to unclog your print head click on next line
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | Canon PIXMA iP90 Mobile Printer
IP90 Canon Printer shows error code 5100: How do I fix it?
This means there is something jamming the mechanism. You should take it to a repair specialist or do your best to check for blockages yourself. It can be the tinest little thing. Check everywhere!
Sep 01, 2009 | Canon PIXMA iP90 Mobile Printer
1p90 remains offline
i have had a little board inside the machine the connects the usb lead to the logic board fail and this causes this fault. You will need to call out a canon service engineer to fix your problem.
if your in the uk i can give you some contacts .
Hope this helps
Sep 30, 2008 | Canon PIXMA iP90 Mobile Printer
Canon iP90 Color Cartridge
Actually this just happened to me tonight as well. Fresh color tank doesnt help. Deep cleaning mode doesnt help. Even physically cleaning the input side of the head doesnt work. Cyan just 100% died today, while the other colors continue fine.
Looks like a print head replacement job now, but so far I cant even find anyone selling iP90 parts online.
The iP90 is now getting consistently terrible reviews on Amazon.
Jan 16, 2008 | Canon PIXMA iP90 Mobile Printer
Error 300
OSX support for Powerbooks is VERY sloppy. Try installing the iP90 in "Classic" (OS9.2.2) instead. 922 has built-in drivers for every port on Powerbooks. OSX can't even load a SCSI card on laptops. Or iRda, or any USB above 1.1 etc.... very shabby. Apple was sued for "abandoning" Powerbook support with OSX and LOST a BIG class action. Alternatively, partition your HD with TWO operating systems, and load 9.2.2 as a boot option (with OSX as the other). OSX is "emulating" 922, but this method allows OS922 to "run itself". It is MUCH faster (boots in 10 seconds, compared to MINUTES for OSX) and your iP90 will work on USB or irDa -both! 922 will only need a 700mb partition at least... OSX needs 4gb or more (to accomplish far less, far slower)
Dec 02, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
old marine
old marine
