Question about Xerox DocuColor 240 All-In-One Laser Printer
Machine not getting magenta, coverage very light and not consistant
Background of the complete surface of the white sheet exits with a pale Magenta coverage, also the Xerox testpage.
It's the magenta drum that's causing the problem so you'll have to replace the imaging unit.But first try removing the imaging unit and cleaning the laser windows and the metal contacts.
Oct 26, 2014 | Xerox Phaser 6125 Laser Printer
What's Markov chain in cheap full coverage car insurance?
The Markov chains in cheap full coverage car insurance it really issuch as synonym zing course of actionon the chains which consists of the Markov chains with theassistwith the search policies it's generated in the scrapping atom of your feeds and search benefitswith all the chains policy holders.
May 24, 2013 | Audio Players & Recorders
HP COLOR LASERJET CP 3505 N PRINTER: Magenta toner is light in color.tryed changing the...
Known problem with this machine the fan is located next to the magenta laser scanner at the base of the machine. this fan blows dust on to the scanner lenses and makes the prints light. Needs to be taken apart and cleaned. take it to a local service center if they know what they are doing should be less then an hour.
May 18, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
I have a Oki C9500 laser, the magenta print is streaky
I have the same problem with my OKI c3100, please help
Jan 13, 2010 | OKI C9500dxn Led Printer
Error message imaging unit is out
Hi rmcday: Here your problem. The imaging unit creates the image using an electro-photo process. The imaging unit consists of the following: ■ An OPC Drum ■ Waste Toner Assembly ■ Charge Roller Assembly 9.0 Consumables, Routine Maintenance Items and Options Item Life based on 5% coverage Part No. Replaceable by Black Standard Toner Cartridge Black High capacity 3,000 7,000 106R00679 106R00684 User replaceable Cyan Standard Toner Cartridge Cyan High capacity 2,000 5,000 106R00676 106R00680 User replaceable Yellow Standard Toner Cartridge Yellow High capacity 2,000 5,000 106R00678 106R00682 User replaceable Magenta Standard Toner Cartridge Magenta High capacity 2,000 5,000 106R00677 106R00681 User replaceable Imaging Unit 50,000 images 108R00593 User replaceable Transfer Belt 50,000 images 108R00594 User replaceable 500-Sheet Feeder N/A 119650600 Waste Toner Cartridge 3,000 to 5,000 pages (color 5%) 106R00683 User replaceable. Your imaging unit may have exeeded it life of 50,000 pages and will need to be replaced. Hope this helps
Jun 10, 2009 | Xerox Phaser 6120/YN Laser Printer
Red is printing pink.
A manual and troubleshooting guide for your printer can be found here.
May 05, 2008 | HP Color LaserJet 2600n Printer
Xerox DocuColor 240 All-In-One Laser Printer Logo
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
