Question about Denon AVR-1600 Receiver
Denon DRA-335R turns off or changes the source or radio station
I can't find a way to provoke any of these situations.
It happens ocassoinally.
I thought that maybe a wi-fi router may be a couse but today it happened when I wasn't using internet [but router was turned on]
I have the exact same problem with my Denon 1600 receiver. I bought the receiver 3 weeks ago and I've been trying to solve this problem ever since. The guys in the "Magnolia" room at Best Buy said it might be a defective receiver, or maybe the receiver is not compatible with my Brighthouse cable box. I think I might swap out the receiver this weekend to see if that solves the problem.
Posted on Dec 10, 2009
My Denon Audio precision am fm DRa 435R Reciever will not stay on station very long. After about 30 or sometimes 45 minutes it get off station. I have it set to a local FM Station, 97.9 and it plays good...
OK,this is a fairly common problem with digital tuners, I get them from time to time in my shop, you see, what is happening is the voltage that's used to tune the set, usual;y stays rock solid, your device however is drifting off station due to this voltage changing, usually it is in the powers supply or the actual tuner itself. It can be bad capacitors, bad IC's, bad transistors, bad tuner module. Sometimes it maybe a "Dry Joint" too.
The only fix is either a replacement PSU or Tuner or indeed maybe both? One simply cannot tell exactly without examining the unit.
You need to take this unit into a Denon repair center and ask for a "Quote" as to costings etc. Once appraised of that one can proceed from there?
Contact a Denon head or local office and ask them there, for a referral to an authorised service center.
Jul 18, 2011 | Audio Players & Recorders
When i search radio chanel with SCAN UP of DRA-275rd radio, he stop on a near frequency but not exact frequency, so i cant to tune in a station. could you help me please?
Check on the back of the unit for a switch marked "channel step" or something similar.Usually close to the anntena socket or connection.When you find it switch it to the alternative position.This should solve your problem.
Jun 18, 2011 | Denon DRA-275R
Loud distortion through phono inputs
Phono inputs are designed for turntables only. Any other device will provide too high a signal for that input to handle. The phono input has an extra amplification stage built in. The distortion is because of the high suignal level being supplied to the input. The only way to get this to work properly is to purchase an antenuator which will decrease the signal level to the phono level.
Dan
Dec 18, 2009 | Denon Audio Players & Recorders
Denon DRA-354r
I have traced the fault to the rf amplfier transistor in the tuner "can" It is a 4 pin item with 6JK85 on the encapsulation but have been unable to source a replacement. Can anyone help?
May 27, 2009 | Denon DRA-455 Receiver
No Power
There is a thermal fuse built into the main transformer. It is possible that the fuse is open.
Dan
Mar 30, 2009 | Denon DRA-365R Receiver
Denon DRA 397 Won't Turn On
me too did you ever get it fixed
Dec 16, 2008 | Denon DRA-397
Denon DRA 335R changes from tuner to phono by itself or turns off by itself
Hi
One thing that may help you with the problem is to power the amp right down by disconnecting from the wall socket, and then power up again 30 mins later. This will allow for a complete reset of the microprocessor stages of the unit. Try this and let me know how you get on. If the problem does not go away, happy to talk to you more about it.
regards
robotek
Nov 09, 2008 | Denon AVR-1600 Receiver
Denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Oct 13, 2008 | Denon DRA-397
Denon DRA-555 Memory won't hold set FM stations when powering up
Most probably the memory capacitor / battery inside soldered to pcb
Jun 06, 2008 | Denon DRA-455 Receiver
No radio
The front end is bad on this reicever. Your going to need special equipment to trouble shoot this problem, as Its all RF. It is most likly not worth repairing as a shop will most likly charge you more then its worth
Sep 16, 2006 | Denon AVR-1100 Receiver
Denon AVR-1600 Receiver Logo
331 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
