Question about GE Quiet-Aire Ductless Heat Pump Split System AS1RD09AA0/AS0RD09AA0
Ductless heat pump - how many and where located in home
a) how many and
b)where should they be located in my home,
additional details - Cape Cod home, 2 story with 2200 sf total (1100 sf each story) with lots of hallways and rooms?
    President:
  • 1,304 Answers
I live in sandwich and am mitsubishi expert
please call
508-420-3922
yellowdog services
to much to type here
Posted on Oct 05, 2009
  • milten1
    milten1 Oct 05, 2009
    please call i live on cape
    and install these units
    i am also a mitsubishi cert installer
How do I clean the filter
It will be located on the front of the unit. Depending on the type, the front should just pull forward to release the front and you'll be able to access the filter at that point.
Sep 17, 2014 | Fujitsu AOU12RLS2 Ductless Outdoor Air...
Tip
Ductless Heating and Cooling of the Hard to Duct Home
You are <b>building a log home</b> or a home that you want the rustic look of the <b>floors above also being the ceiling of the floor below</b>. You hate the thought of having to install ugly <b>heating and air conditioning ductwork</b> in your new home. For you there is hope. You can still have a comfortable home and have the look that you want.<br /> <br /> The advancements in <b>ductless heating and cooling</b> has made it possible for you to have those wood ceilings, roof lines, wood walls, and everything you can think of. The new <b>ductless HVAC units</b> take up very little space on your wall. They can be placed almost anywhere with a little planning, and they are<b> very efficient at both heating and cooling</b>.<br /> <br /> The many features do not stop with the<b> heating and cooling</b>. Most units have remote controls to run the unit. Many of these units can run <b>multiple inside units from one outdoor unit</b>. These units are so quiet that you have to feel the air coming from them to see if they are running. The installation has been simplified to the point that they can be installed very quickly by an <b>experienced professional</b>.<br /> <br /> If you are concerned about the looks on the outside, that too can be fixed rather easily. The <b>piping and wiring going to the indoor units</b> is relatively small and can be hidden in many ways by using a little imagination. Colored aluminum can be fabricated to cover the pipes. I have also run the piping through rain spouting and made it to look like just another rain spout coming off of the roof. <br /> <br /> If you are looking to build or remodel and are worried about the look you will have on the inside, then take a look at <b>ductless split heat pumps</b> to give the comfort and the looks.<br /> <br /> Good<b> heating professionals</b> can find many ways to make these units work for you. Make sure that you do not settle for something less than you want. You may need to look at more than a few companies to find the one that will give you the system that you want.
on Feb 19, 2011 | Heating & Cooling
What are some examples of home automation?
HVAC, centralized control of lighting, automatic security systems, applicances, etc
Jan 30, 2013 | Home Automation
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
How to use thermostat for heat on Fujitsu IAQ halcyon
This unit comes with a remote control (optional wall mounted wired thermostat available) as a standard feature. This unit is precharged with the environment friendly R-410a refrigerant. No additional refrigerant is needed if the line set is 49 feet in lenght or shorter. In addition to its very high 20 SEER efficiency rating, the 15RLQ is only 31 in. long which makes it the smallest Mini-Split System in its category through out the industry.
This category of equipment is ideal for smaller spaces where spot cooling is required. Several models in this category are ENERGY STAR Certified, meaning they save you money on your utility bill. Residential applications including sunrooms and additions are made easier with these air conditioners and heat pumps. Do you have a warm spot in your home? Fujitsu mini-splits can provide extra cooling capacity for those hard to cool areas. Commercially, their small size makes them ideal for small offices, providing individual temperature control.
Fujitsu's I.A.Q. Systems provide residential and commercial property owners an innovative solution for clean, temperature-controlled indoor air. The Halcyon IAQ systems deliver powerful heating and cooling, are designed for ease of use and maintenance, and feature an unobtrusive design which can be integrated easily into any decor. The Halcyon IAQ systems filter dust, pollen and odor making them the perfect addition to any home!
  • Wireless Remote Control
  • Plasma Filter
  • Sleep Timer
  • 24 Hour Timer
  • Dry Mode
  • Auto Louver: Up/Down
  • Auto Mode
  • Quiet Mode
  • Auto Restart/Rest
  • Auto Changeover
  • Low Ambient
  • Cold Prevention
Warranty All Fujitsu ductless mini-split air conditioners and heat pumps come with a 2 year parts and 6 year compressor warranty.
Important: All installations must be performed or supervised by a certified HVAC technician in order for the warranty to be valid.
Dec 08, 2009 | Heating & Cooling
Ductless minisplit in old mobile home
ductless mini split units are a very good choice!  they are obviously quieter, more efficient and easier to maintain than window units. the downside is the initial expense of buying the unit, but this is paid back in eletric savings and peace of mind. Good luck Peyton
Mar 07, 2009 | Soleus KFR12GWD 12,000 BTU Heat & Cool...
Ductless heat pump systems
Heat pumps do loose their heating capacity and efficiency as temps drop. If you decide to rely on a heat pump you may want to make sure that your system has a back up heat strip, maybe even controled with an outdoor thermostat, if that is an option. The Mitsubishi is a great product.
Nov 15, 2007 | Mitsubishi MSH12TN Air Conditioner
GE Quiet-Aire Ductless Heat Pump Split System AS1RD09AA0/AS0RD09AA0 Logo
201 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
