Question about Intex Castle Bouncer
I need a cap for the bottom section. - Intex Castle Bouncer
  • 33 Answers
Get a strong piece of plastic and find the strongest black tape that should do the job
Posted on Sep 29, 2009
Neovo F-417 contantly autoadjusting - help!!!!!
Check to see if the auto button is sticking (press it hard a few times, and wiggle it)
If it's not that then It's probably the power supply blinking out (monitor thinks it was shut off and back on)
If so, There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Mar 01, 2011 | Neovo F-417 17" LCD Monitor
Tv comes on than go off in 3 to 5 seconds
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
Mar 01, 2011 | LG 42PG20 42 in. Plasma HDTV
The tv will not turn on and there is a beep coming out of the back of it. It is 8 yrs old. thx
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both. The beep tends to indicate the inverter section should be looked at first!
Mar 01, 2011 | RCA Televison & Video
Screen flashes protection
Mar 01, 2011 | Televison & Video
I have a toshiba tv and it turn off by itself.
Mar 01, 2011 | Toshiba Televison & Video
WILL NOT TURN ON
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both. These may have blown a fuse too, so check for that!
Feb 28, 2011 | Philips 47PFL3603D LCD TV
Dark bottom screen in TV
You have a problem in the vertical section of the TV and it could be just a bad electrolytic in the vertical section, if you replace all the caps in the vertical section that should take of your problem.
Dec 06, 2010 | Televison & Video
Lg tromm front load leeks water from somewhere around bottom of mach.
You most likely need to clean your pump filter and the drain hose next to it. Both are located on the lower left section of the washer's front side. There is a door (cover cap) you need to simply pull open to gain access to the two items I mentioned. The cleaning process is available in your owner's manual - in the maintenance section.
Jun 15, 2009 | LG Washing Machines
Washing machine doesn't spin spindel
whirpool part# 80040 agitator dogs need replacing remove center cap remove bolt in agitator pull top section up ..may need to hold bottom down and pull up sharply on top section to separate
Nov 06, 2008 | Roper RAS6233KQ Top Load Washer
Picture is cut off
check all electrolytic caps on the vertical deflection section, to make sure replaced all caps in the vertical section for it is cheap this might solve the problem
Sep 19, 2008 | Samsung LTM295W 29 in. LCD Television
Intex Castle Bouncer Logo
43 people viewed this question
Top Intex Toys Experts
ray gallant
Are you an Intex Toy Expert? Answer questions, earn points and help others
