Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Husqvarna YTH2348 engine stall issue 23hp B&S. Full charge on the battery 12.7vdc. New fuel filter. 13.5 - 14vdc at full throttle. Cranked right up cut grass 20 minutes +/- begins to sputter as if starving for fuel and kills. Don't see any vent holes on the exterior of the fuel cap. Interior holes clear. When I turn the key I hear a click that I'm assuming is the fuel supply solenoid energizing. After a minute or two it will restart then cuts for 10 minutes before the symptoms return. Noticed that the fuel filter bowl is nearly empty. I have not inspected the fuel tank dip tube or the fuel pump because I'm not sure they are serviceable. Grass is REALLY long...cash, on the other hand is really SHORT. Any ideas will be helpful!!
  • traboH Mr
    traboH Mr Oct 10, 2009
    Seriously, dmorris6498 move on.
    I thought I made it pretty clear in the post that I've checked the basics
    Anybody else have a more appropriate suggestion? thanks!
Mine was doing the same thing. Just loosen the gas cap. If its on too tight the engine will stall because the air cant get into the fuel cell to replace the abscent fuel.
Posted on Sep 30, 2011
  • 3 Answers
Don't forget the safety switches, check one under seat.
Posted on Sep 26, 2009
My husband bought a 2011 Husqvarna YTH2348. I am the one that mows the grass. We had the mower serviced last week. We have a HUGE lawn and I mowed all but the orchard. The next day, I went out to finish...
Black smoke is generally indicative of a rich fuel system. whitish blue smoke is generally burning oil.
It sounds like there is something wrong with the fuel metering at full throttle. You might check that the mechanical compression release isn't coming on when you go to full throttle.
Aug 17, 2013 | Husqvarna Garden
I need a drive belt dagram for a husqvarna yth2348 hydrostatic
Looking at the IPL(exploded parts list) will give you a good look at the route of the belt. Here is a link to use and find your model
http://www.husqvarna.com/us/support/download-manuals/?query=yth2348&types=I&brands=
Apr 20, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
2 cycle engine speeds up then stalls
1 turn out is approximate setting fo H and L screws...once running adjust H screw so that it is just rich at full throttle (4 stroking then 2 stroking with out changing screw) once thats right adjust L screw at idle till it starts to pick up speed then just back off 1/8 of turn ....then you can adjust tapered screw to nice idle....if this fails you have carby problem
Jul 26, 2010 | Husqvarna Garden
Husqvarna yth 2348how to check and see if battery is charging and
there are one to two wires that come from under the fly wheel. thy are attached to our stator (charging sys) the flywheel has a magnet on it. know the wires my or my not go to a voltage regulator than a fuss and to ether the solenoid battery side, or to the battery. the easy way to check is on your battery with a meter. check battery fri st than start your engine to see if the amps come up should be around 12.9 to 14.6 volt. make sure your at full throttle. good luck, let me know.
Oct 16, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH2348 stalls after 20mins
First thing to do is check and repair charging system. They are/could be related problems in that there is an electric fuel shut off solenoid on the carburetor and if the battery is going dead, it could be cutting off the fuel flow. I wouldn't worry about the spark plug or cleaning the carburetor just yet.
Put a meter on the battery terminals, run the engine at full speed and check the voltage, If you are not getting around 13,5 volts going back to the battery, repair/replace the charging system. If it is less than 2 years old, it should still be under warranty so you might want to check with your dealer. I am guessing that it is a B&S 23 HP and replacing the alternator can be expensive and time consuming
Sep 20, 2009 | Garden
Yth1848xp bogs down at full throttle when engaging the mower
Carburetor could possibly need cleaning or rebuild, Governor linkage could be dirty and not operating freely, or it could be out of adjustment
Sep 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a Husqvarna yth2348 lawn tractor. It starts fine, but won't start if I turn if off after running for a while. I can hear the starter engaging the engine, but it doesn't seem to have enough power to...
You didn't mention how long it worked with the new battery so here are a couple of things to try. Using your car/truck and a set of jumper cables if you have them, see if it will start,just be sure that they are hooked up properly.
Use a volt meter and test the battery. It should have at least 12 volts. Get the engine started and at full throttle, again test the battery, it should be showing 13 to 14 volts indicating that it is charging. If not, your charging system is the culprit. If charging system is good, then it may well be the starter, Remove the starter and take it to a lawnmower repair shop or do-it-yourself auto parts store and have it checked. The starters are VERY expensive depending on the brand of the engine so you want to be certain that it is bad before buying a new one.
If all this is good and/or it sounds like the engine makes about a half of a turn before bogging down and not starting, it could well be that your valves need adjusting or in worst case scenario, your automatic compression release inside the engine has failed
Aug 10, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Engine stalls after 45 minutes?
Hi..my name is Keith...i would suspect either the fuel cap isnt venting..or if you have a fuel pump..that it is bad..i hope this will help..if not please write back
Jul 08, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna YTH1848XP Riding Mover stalls with throttle increase.
Check your Vacuum line going into the back of your air intake box.
Jul 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
620 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
