Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-62628 power shuts off!
After a few minutes of turning my 62" mitsubishi WD-62628 projection tv, it automatically shuts off and then the little green timer light start flashing. Anyone have an Idea of what is possibly going on?
  • 3 more comments
  • Mike626 Dec 19, 2007
    After it turns of the code t reads out is 12
  • majelken Feb 05, 2009
    Happened after power went out and came back on. Initially the net command screen came up but wouldn't let me select device (blank blue screen). I shut the tv off, but it would turn back on. unplugged for a while and reset. would not come on. left unplugged overnight, came on to the net command screen, but it was froze ( i left this on for over 24 hours for the store that I bought from could look at it). After resetting again will not turn on. Green timer light blinks but will not power up. Help!
  • Anonymous Mar 17, 2014
    I have the red light when off and when I turn it on a green light, I can hear it turn on but nothing ever comes on the screen. After a few minutes it goes back to red.
    will not stay on
  • Anonymous Mar 21, 2014
    One side is Black
    President:
  • 4,402 Answers
Hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
  • Cary Farah
    Cary Farah Dec 19, 2007
    12 = No error detected, check power supply.
    **Possible cause: **You may have a bad DM Module!**
    It is highly likely the root cause of the failed DM Module are the
    blue, electrolytic PTH Capacitors on the board..
    http://www.hdtvoice.com/voice/showthread...
    Problem Solver:
  • 6 Answers
I have the same issue have not done the repair yet but here is a link to photos of the various boards and the problem caps:
http://www.fixya.com/support/t155026-
flickering_blue_picture
Posted on Feb 16, 2008
SOURCE:
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
You most likely have some faulty capacitors on the power module. You can easily identify a bust capacitor. They will have swollen tops. Here is a sample pic:
Check the specifications of the faulty capacitors, and getthe replacements from your local electronics shop. If you are comfortable withthis, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out thedefunct capacitors. Once that is done, solder in the new capacitors carefully. Ifare unsure how to do this, try to get a friend who knows this kinda stuff to doit for you, or get a qualified technician.
Warning: If you do not have a background inelectronics repair, or are inexperienced, get a qualified technician to do itfor you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
If you want to go in for a long term solution, youcan easily replace the whole power board. You can get spare from HERE.
They also offer FREE online technical advice as you do the DIY..
Hope that helps!
Oct 03, 2008 | Televison & Video
I have a wd 62725 mitsubishi digital tv. the timer light keeps blinking fast and cant turn on the tv nor watch it what could be the problem
Try pressing power button for 10 seconds or until it turns off. Wait for 1 minute and turn it on again.
BTW, I own a 73 inch model.
Jun 22, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Trying to access the device menu on our WD 62628 causes the system to reset itself. Help!!
Reset the tv by pressing menu and 2470 then enter. If this doesn not fix then you have either a bad e2p or dm.
Jul 04, 2010 | Mitsubishi WD62628 62" Projection HDTV
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
WD-62628 Mitsubishi DLP
Here is the picture for a Mitsu62525 power board, which is similar.
You recognise it because you get power cables innesting into the power board.
If you decide to work on your TV, get the service manual first.
Oct 10, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Wd 62628 tv
After I reset the system, the Audio menu gave me access to the TV speakers that had been turned off. I turned them on and had to wire audio cabes from my sat box to the component audio in on the TV.
Sep 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
MITSUBISHI BIG SCREEN MODEL #VS55707
1. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. IS the set shutting off or the hor. lines?
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Jul 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,081 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
