Question about Refrigerators
Refrigerator does not stop running
The refrig will continue to run and freeze everything. Doesn't happen all the time. Maybe every other month. its the stanless steel 4.4 frig.
    President:
  • 1,653 Answers
Sounds like a faulty thermostat so get it replaced asap.
Posted on Sep 26, 2009
Refrigerator runs continuously
How well are the door seals and the door to the ice dispenser is it closing all the way. Condenser clean?
APPLIANCE 911
Apr 14, 2016 | Frigidaire Refrigerators
Will not turn off. Thermostat control clicks but refrigerator continues to run in the off position and therefore will freeze everything inside.
Check for a small wire sometimes copper color that ends in a small bulb in the refrigerator. Then check to make sure this sensor is not unplugged from its source. This if the thermal sensor that measures temp in the refrig
Nov 04, 2013 | Haier HSA04WNCWW 3.9 Cu. Ft....
Model GBS18HBPPWW - refrigerator freezes up. Turn it off and after the ice melts (under the base of the bottom of the refrig section) is runs again for 4 to 6 months and then happens again.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | GE Refrigerators
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Coils behind the freezer continue to "freeze up"
You have a problem in the defrost system There are three components: Defrost timer, defrost thermostst or terminator, and defrost heater. One of them has failed which is causing the evaporator to ice.
Apr 09, 2009 | Refrigerators
Kichenaid refrig not keeping cold
Need to have someone with multimeter check the compressor and the capacitor. May be the start capacitor not allowing the compressor to run or continue running. Let me know, Sea Breeze
Mar 19, 2009 | KitchenAid Refrigerators
Refrig not working
what brand is this?? Model#? Is the freezer fan working?? Is the compresor running?? Is there any frost on the back panel in the freezer??
Dec 25, 2007 | Ovens
Freezer not freezing, everything is thawing.. only 3 yrs old, refrig part only 47 degrees
sounds like your compressor is not starting up. unplug your refrig then remove the start relay from the side of the compressor. shake the relay if you hear alot of rattling around in the relay then most likely that is all thats wrong. if it doesnt rattle alot then possibly the compressor is locked up and is bad.
when you shake the relay if its broken internally usually little peices of ceramic will fall out of it. so shake it over a peice of paper to see if that happens/..
Dec 16, 2007 | Jenn-Air JCD2290HES Side by Side...
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
