Question about Lexmark All-in-One Printer with PictBridge
Printer doesn't print
What does ''printer is currently off-line'' mean?
  • Lexmark Master
  • 4,338 Answers
Go to start>printers and faxes> double click on your printer> click on printer on the top right of the open box> then remove the check mark on "use printer offline"
Posted on Sep 26, 2009
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
I have a printer thats printing on one side only. how can i fix this
Do you mean double sided printing? If so this model printer does not have a duplex unit and cannot print double sided prints automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will beprinted on the other side of the page 1).
Repeat this procedure for the other pages.
Jun 15, 2012 | Brother Office Equipment & Supplies
Okidata B4600 error message #132 on two printers. What does this error mean. The printers will not go to off line.
Error 132:
LED Head Missing, Color:Magenta
When magenta LED head connection cannot be detected
Solution:
You should first try to restart the printer.
If that doesn't resolve the problem, the ribbon cable is probably disconnected from the print head.
The led print heads are four assemblies that hang down from the lid of the machine when you open it. Make sure they are properly connected.
Sep 14, 2011 | OKI B4600 Printer
E07, e08, e02, e15 error in canon mp258, pl. give meaning of error & solution
Canon Pixma Mp258 Error Code and Possible Solution
P02 (Carriage error)
1.Make sure no foreign material stuck to the print head railway.
2.Clean and check the print head encoder strip cable (timing **** film or encoder strip is a white line on the back of the box set of ink lines may be missing or mess up the ink.P03 (Line feed error): an error in transmission line entering the line feed (LF) is a signal telling the printer to move to another line or a whole new line that would not otherwise have reached the end of the line.
1.Check wire print head position (timing **** disk film) on the side of the machine.
2.Check PCB logic board.
P05 (ASF sensor error) sensor for paper feed error.
1.Try to replace the following:
•ASF / PE sensor unit.
•Drive unit.
•PCB logic board.
P06 (Internal temperature error): caused by abnormal heat inside the printer.
P07 (Ink absorber full): the Ink Wastepad (sponge) inside the printer is full
1.Replace the wastepad inside the printer or install waste ink bin outside the printer
2.then Reset counter protection.
P08 (Print head temperature rise error): caused by thermal print head temperature exceeds a threshold.
1.Replace the new cartridge print head and / or change a new logic board.
P09 (EEPROM error): caused by corrupted or defective EEPROM chips of the printer.
1.Replace the logic board.
P15 (USB VBUS over current): caused by too much current, try removing the USB cable and then plugin again, if solve the error, try to replace with a new USB cable. If the error still exist replace the logic board.
P20 (Other hardware error): The failure of other hardware.
1.Try to replace the logic board.
P22 (Scanner error): a scanner malfunction.
1.try to change the scanner unit or change a the logic board.
E13 or E16: Ink has run out
1.Pressing the Stop / Reset button for 5 to 8 seconds until the led screen display number 1.
E04, E05, E14 or E15: Cartridge may not be installed properly
1.Reinstall the ink cartridge.
Jun 15, 2011 | Office Equipment & Supplies
Where do I load the staples in the machine
Your printer doesn't support automatic stapling, In fact it doesn't support much at all. It is a single funcion printer meaning that it doesn't have fax or scanning, printing only. You would of got it for about $50 right? Sorry but it has no stapler.
Jun 05, 2011 | Canon PIXMA iP1800 Printer
When I print a photo, vertical lines appear throughout the photo. The ink cartridges are new. No error message appears on screen.
Please state the model of your printer.
Vertical lines appears on prints because the nozzles on your print head are blocked, it doesn't means all nozzles but some of your nozzles are blocked. A print head of an inkjet consists of many tiny little pores or nozzles, through which jets of inks are sprayed on the photo paper to create an image, if some of this tiny pores are blocked print outs deteriorates, so cleaning the print head is an option if your printer has print head inside the printer you can first clean it through the head cleaning option present in the maintainence tab of your printer software, for printers that have print head on the cartridges, you can add a few drops of isopropryl alcohol on the print head and leave it for a minute and put it back on the printer and run the head cleaning utility of your printer software.
Hope this helps you.
Apr 28, 2011 | Office Equipment & Supplies
My brother mfc-490cw I can't send or recieve faxes.
According to the User's Manual for the Brother MFC-490CW:
  • Poor Line Connection indicates an issue with your telephone line (Page 136). If you are sharing the fax line with any splitters or computers, try connecting the MFC-490CW directly to the phone jack and send a fax. If you are still getting a Poor Line Connection error message, call the telephone company and have a repair technician check your telephone line.
  • Out of Memory error message means the machine's memory is full (Page 138).
    Try pressing Stop/Exit and wait until all current operations finish and try again.
    Try clearing the data in memory. To gain extra memory space. turn off Memory Receive (See Page 48).
    Try printing the faxes that are in memory (See Page 49).
  • System Busy error message wasn't in the manual, but I suspect it means there's a current operation in progress and the machine needs time to finish before moving on to another job. Just wait for the current job to finish, then try again.
May 05, 2010 | Brother MFC 490cw Color Inkjet...
Language
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Feb 15, 2008 | OKI MICROLINE ML-395 Matrix Printer
Problem with oki microline 395
Enter the menu,
Menu Mode
2. Power ON the printer4.gif.
5. The line shown below will print4.gif.
Step A
Step B
A line prints4.gif, showing the Group.
Lexmark All-in-One Printer with PictBridge Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
