Question about Ricoh Aficio 1035 Copier
I have a ricoh 1045 , and I can not read the display looking down, but I can see everything in an angle. Can you help?
  • arbame Sep 26, 2009
    Problem solved.Thanks copydoki
  • Ricoh Master
  • 1,297 Answers
See the display panel contrast button position(in the left side to user tools button.).If not work perform the touch screen adjustment:Press the total stop key(yellow)-1-9-9-3-clear/stop key(red button) x5 timeand press enter key(double croice).The graphic sensing adjustment screen will appear.Touch the upper left corner then the lower right corner of the panel using a pointed tool.Touch a few spots on the LCD and confirm that the marker appear on the screen at exacrly the same location as the pointed tip.Touch enter on the screen adjustment.Turn off the machine and back on to store the settings.
Posted on Sep 26, 2009
Testimonial: "followed instructions and it worked. Thanks copydoki"
  • 541 Answers
These back lights burn out just like the computer lcds. is your display dark?
Ricoh 1045 firmware
what exactly do you need. You will need special service card also. You better call technical support
Sep 03, 2014 | Ricoh Aficio Office Equipment & Supplies
Microwave genius sensor 1300w
I don't believe it is possible to change the display angle/tilt on this microwave. The unit ships with a protective film over the display that should be removed to make the display easier to read. However, this model is known to be difficult to read unless looking at straight-on. That and needing a flashlight to look at your food with the door open since the internal light does not stay on when door is opened. Good luck!.
Jun 13, 2014 | Panasonic NN-SN657SMicrowave Oven
Photocopies are not clear even after increasing image intensity.
if you have over approx. 60-100k copies on the machine it sounds like you may need regular maintaince on the machine.
to check how many copies you have press the user tools/counter button and then press counter.
Jul 13, 2013 | Ricoh Aficio 1045 Black and White Copier
RICOH AFICIO 1045. ANY BUTTON AT RIGHT OF THE ...
turn off and unplug remove two screws on top near the glass jn order to remove the control panel slide panel toward your tummy bottm side has wiring harnesses check these connectorsare tight also look fer cracked solder joints on right side for numeric keypad if you know how to soldera pcb new control panel is about 800.00
May 21, 2010 | Ricoh Aficio 1045 Black and White Copier
Hello, got an old Aficio 1045 with headcrash. I
The 900 code is the software error code.Enter in theuser and SP modes and configuration the new duplex.For more information please answer.
Sep 28, 2009 | Ricoh Aficio 450 Copier
Error code SC998 on Ricoh Aficio 1045
The error code 998 is usually for the dimm or application boards read errors try taking the memory out and the app board out and reseat them again.. then go into the service mode via yellow clear button and then enter 107 then hold down the stop button till the panel changes and turn off the copier wait for 5 secs then turn back on.. If you dont know where boards are take the back panel off and on the right hand side there is a box with a steel plate on the dimms Ram..and app boards are there.. Good Luck A..
Jul 30, 2009 | Office Equipment & Supplies
Ricoh aficio 1045 error e990 please help it
This is a software performance error; However it is most often caused by a deteriorating drum unit. There is no exact solution, but 9 times out of 10, a new drum unit, and fresh developer will solve it.
Outside of that, it is likely a board problem -possibly BICU
May 26, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1045 User Key
Someone locked the machine out. You can a hold of who your purchased it from to see if they can give you the key operator code to unlock it.
I can give you the service code to restore it but there are several steps involved in doing that.
If the first option doesn't work, let me know and I'll look up the service program to disable the key codes.
Sep 01, 2008 | Ricoh Aficio 1035 Copier
Ricoh 1045 only printing on 1/2 page
When you put the delveloper did you:
remove the cover to install it.
remove all of the old developer out of the machine.
Did you go into service mode and run sp 2-801.
Jun 30, 2008 | Ricoh Aficio 1035 Copier
Service code SC546 on a Ricoh Aficio 1045
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and then turn the main Power switch Off then back ON... You do not have to do any thing in service mode, just get to that display.... Don't change anything unless you know what you are doing. sc546 has to do with the fixing unit. You may be able to reset it.
Jun 03, 2008 | Computers & Internet
Ricoh Aficio 1035 Copier Logo
279 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
