Question about OTC 1910 Truck Wheel Bearing Locknut Socket - 3 - 1/2"
Change front wheel bearing on fiat ducato 2.3 jtd 2004
Fiat multipla jtd continuous noise like a wheel bearing going when driven but stops on a slight right hand steering lock
You have a bad wheel bearing. It is a double row roller bearing, side-by-side rows. One to the inside and one to the outside. When you steer side to side, the load transfers from one set of rollers to the other. When steering to the right, the load shifts to the left side. The side of the car where the noise is most pronounced is probably the suspect side.
Jan 09, 2018 | Fiat Cars & Trucks
Hi I have a fiat ducato 2.8 jtd and conrod has spun a bearing and cannot read size on it as its disintegrated how do I find number four it number 4
take another cap off and read the size
what you are doing is a short cut to costly repairs as a spun bearing usually requires a new con rod as well as bearings
Aug 25, 2017 | Fiat Cars & Trucks
How to check valve timing and injector timing on Fiat Ducato 2005 2.8 JTD engine?
If I knew the answer the description would be too protracted for the space and time available here.
You are likely to be able to find a how-to video on youtube. If the injection system is a common rail type the timing will be electronically controlled.
Engine manufacturers are increasingly not using timing marks as the engines are built by robots and timed by jigs, and an increasing number of setting tools are needed to work on engines in the aftermarket.
Aug 08, 2016 | Fiat Cars & Trucks
Fiat ducato 2.3 jtd none starter!
have you had the injector spray pattern checked ? i would advise getting that done and then work backwards from a known good component, also have you had the OBD codes read as these should help pinpoint the sensor/switch etc at fault , actually do thes ethe other way round OBD first , keep me posted if you wish
May 13, 2015 | Fiat Cars & Trucks
Fiat ducato van 2litre jtd turns over but wont start,but will start straight away with ajump
strange that it should start with a jump ,i would be looking at the battery to make sure not a dead cell in it
Oct 15, 2011 | Cars & Trucks
How to change air filter on fiat doblo 1.9 jtd
how to change a engine air filter on a Fiat emoction multijet 1.9 jtd
Sep 12, 2009 | 2006 Fiat X1/9
OTC 1910 Truck Wheel Bearing Locknut Socket - 3 - 1/2"  Logo
213 people viewed this question
Top OTC Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you an OTC Hand Tool Expert? Answer questions, earn points and help others
