Question about Garden
Need to know how to change front dust cover on Husqvarna 5521Ch. Can get wheel off; but then I am stumped where to go from there.
  • bbreton
    bbreton May 11, 2010
    Not sure what you are calling a dusty cover? There is a drive cover that protects person from getting in the drive belt area. It is held in place with one screw.
  • 389 Answers
Locate and remove the E-Clip that holds the pinion gear (the steel gear that drives the wheel) on the transmission shaft then remove the pinion gear. That is all you need to do to replace the dust cover
Posted on Oct 04, 2009
Husqvarna 1100 sewing machine will turn on for 1 second and then dead as a door nail. Plug- ins are good. Stumped?
sounds like a faulty thermal capacitor. have you taken the cover off and cleaned lint from inside the machine lately?
Sep 02, 2017 | Husqvarna Sewing Machines
Need to know where all grease fitting areon husqvarna lgt2654
One on each front wheel rim. One on each end of the cast iron front axle. Three on the deck. They are on the top of each spindle. There are no other grease fittings.
Feb 01, 2017 | Husqvarna Garden
How to replace front wheel bearing on 2003 kia sedona
Disassembly 1. Remove oil seal from front wheel hub. 2. Remove front wheel hub assembly with suitable tool.
bi6c021a.gif 3. Remove retaining ring. note_icon_eng.gif If the bearing inner race remains on wheel hub, grind a section of inner race until approximately 0.020 in (0.5 mm) remains. Remove race with a chisel.
bi6c021b.gif 4. Remove wheel bearing with suitable tool.
bi6c021c.gif note_icon_eng.gif Do not remove dust cover unless necessary. Do not reuse dust cover if removed. 5. Mark relative positions of dust cover and knuckle for proper reassembly. 6. Remove dust cover with a chisel.
ai2a023c.gif note_icon_eng.gif Do not remove wheel hub bolt unless necessary. Do not reuse wheel hub bolt if removed. 7. Remove wheel hub bolt with a press.
bi6c021d.gif Assembly 1. Press in new wheel studs. note_icon_eng.gif Front wheel hub press in either bolt turning or loosening by the torque of 108.5 lb•ft (147 N•m, 15 kg•m) shall not be premissible.
bi6c022a.gif 2. Mark new dust cover to match the removed dust cover. 3. Align mark on new dust cover with knuckle. 4. Install new dust cover with suitable tool.
bi6c022b.gif 5. Install new wheel bearing with suitable tool. 6. Install front wheel hub assembly with suitable tool.
bi6c022c.gif note_icon_eng.gif Use a new oil seal, and apply grease to seal. Install oil seal so that it is flush with knuckle. 7. Install new oil seal with SST(0K993 331 016).
Jan 12, 2013 | 2003 Kia Sedona
How do i get a front tire off
remove the small dust cover from the center there will be either a c clip or a cotter pin remove the fastener and the wheel will come off
Aug 18, 2012 | Husqvarna Garden
Generic problem for all Ford Escape Cars Front wheel bearings are noisy,need to change? how to?
Front wheel drive should be done by a shop. Rear wheel drive just a matter of removing the front wheel dust cover and remove the spindle hub. It is self explanatory thereafter.
Oct 27, 2009 | 2004 Ford Escape
Need to replace front left tire. Can't get it off
If you have removed the hub cap (dust cover), the E-clip or cotter pin and washer from the outside of the wheel, it should just slide off the shaft but you may have a burr of some sort stopping it, try some sanding cloth, about 220 grit and smooth out the circumference of the shaft. If this still does not work, try pumping the wheel full of grease if it has a grease zerk on it. If the wheel turns freely when off the ground, you have something not clean or perfectly round stopping the outer race of the bearing
Sep 07, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Change front passenger wheel bearing
Jack up car, remove wheel, remove dust cover, remove carter pen, remove wheel bearing.
Aug 12, 2009 | 2001 Saturn L-Series
I have worked on many differnt trucks and cars but I m stump on how to get the rear brake drums off this 2000 Dogde Caravan. They must be rusted to together. Or is there a new tech for removing drums?Any...
Forgive me as I cover some bases. I don't know this vehicle. Some front wheel drive cars have wheel bearings on the back like RWD cars had on the front. Older Hondas did this. Dust cap, nut, cotter pin bearing, ect. If not and it looks like it should just come off like always then try a hand held propane torch and heat the fase of the drum and the drum to expand the hole in the center. Move the torch around. If you hear a pop the drum will come right off. They usually go back on fine. The wheel takes care of that. This has always been around, sometimes, older Ford pickups, always it seems.
Jun 06, 2009 | 2000 Dodge Caravan
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
