Question about Toshiba Satellite A105-S4334 Notebook
I am trying to hook up my tv with a vga to av(rca) cable,but I can't get it to work.What do I have to do to get it to work?
  • 11,361 Answers
If your notebook has RCA composite video out, you need to hook it up to TV composite video input jack, usually the color of this RCA jack will be yellow. Why do you not use the VGA port on the back of the note book to feed the signal into the TV's VGA connector, just mke sure to set the resolution of the laptop to be at TV native resolution.
Posted on Nov 04, 2009
Is there any way, an adapter or anything, that will allow you to watch tv through the projector?
TV AV out - RCA cable
to
AV in on data projector
if these ports exist on your Data projector and on your TV
as you did not provide make and model numbers of the devices for us to check if the input and output ports of your devices are available.
if only a vga in on data projector
and av out on tv
https://www.youtube.com/watch?v=F6vF_l3Dh9I
you need to amplify the audio out red and white cables of RCA and connect to speaker that amplify like computer speakers.
google search
TV AV Composite S-Video RCA In to PC VGA Video
Jan 23, 2017 | The Office Equipment & Supplies
CAN I connect 2 tvs.to one converter box and how.
If you're using a box that has an RF (antenna) output on channel 3 or 4 to the TV, you can insert a splitter and feed two sets. A splitter looks like this:
It takes the signal in on the single connector side, and splits it between the two output jacks on the other side. You can find splitters at TV retailers, Radio Shack, and even at Home Depot or similar stores in the electrical section. Run a cable from each of the output jacks to the antenna connectors on the two TV sets. Each TV will need to be tuned to the converter box output channel, and both sets will get the same program (whatever channel you have selected on the converter).
If the converter box has audio and video output jacks and the nearest set has an AV input, you can connect that set with the same kind of cable you use to hook up a DVD player (RCA plugs on the ends) and select the AV input to see the converter box signal. You would run a cable from the RF output connector of the converter to the second set's antenna jack. Then you wouldn't need the splitter, and the set using the AV inputs would get better quality picture and sound. Again, each set will get the same program as determined by the converter.
Hope this is what you need to get going. Thanks for using Fixya!
Dec 17, 2010 | RCA Analog (RCA) to Digital (VGA)...
My toshiba S300m has a VGA socket and no S cable socket. I want to connect the Tosh. with my TV. Problem is that the TV is an older one and has a S video (female) and it also has three (Yellow, white,...
try to lower your video/screen resolution down to what your older tv can take as an input. (try 800x600 or lower) first if that does not work search on eBay for
VGA SVGA TO S-Video 3 RCA Composite AV TV Out Converter Adapter Cable PC Cord
Jun 04, 2017 | Toshiba Satellite Pro S300M-S2403 Laptop
Is it possible to connect the emachines E525 with an LG LCD tv if so how?
It is possible to connect your laptop to any LCD TV. For which you need to locate the external VGA port on your laptop. As your Laptop doesn't have S-Video port you would have to deal with the VGA port.
There are several adapters available in the market which can solve your problem:VGA to RCA orVGA to S-Video orDual VGA cable
Your LCD TV should be equipped with all the ports mentioned above that are:RCA (AV)S-VideoVGA In
But as I don't know the model Number of your TV I don't know whether your TV has S-Video or VGA ports but the RCA (AV) are the most common ones which I am pretty sure you would have.
Here are some pics of the cables.
^Dual VGA cable
^VGA to RCA or S-Video
You can buy these cables from the market and easily connect your system to the TV.
If you need further help, please feel free to contact me.
Aug 08, 2010 | Computers & Internet
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
Can I hook up a cable from my PC VGA output to my TV Component inputs?
As long as the PC and the TV has VGA, YES, you can hook it up from the PC VGA output to TV VGA inputs.
Please let me know if you have any other question.
Thank you!
Feb 19, 2010 | Philips Televison & Video
Hooking up from hd receiver to hdtv ready projection tv. what cables do I use? vga or rca component red, blue, green and sync white/black? My hd receiver has output of :hdmi, rca component, s-video ,...
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Mar 07, 2009 | Philips 60PP9202 60" Rear Projection...
IBM ThinkPad 380Z AV Hook up To Tv
From what I have been reading, the video card in the computer itself MUST support TV out. You can't just use a TV like a computer monitor...it won't work. Check the ads on eBay for those adapter cables and they will say: Check to make sure your video card supports TV out. Go back to eBay and search in the same general area for a computer video to TV adapter or converter box. DO NOT get it confused with the converter box for HDTV. They are about $25-$35 and you will still need the cable adapter you already have, plus another set of just the AV cables. Good luck. Please rate this if it was helpful.
Sep 26, 2008 | IBM ThinkPad 380ED
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Toshiba Satellite A105-S4334 Notebook Logo
226 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
