Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Having Trouble Receiving Through"TPL"
I have tried everything I know to repair this, I have Motorola Programming Software and am a novice at using it to tune the radio I know how to set up and program frequencies and other functions but when I program a Frequency and slap the TPL code into it when I unplug the radio and test it with the repeater, the received audio comes in out in out very rapidly, so much that it makes it hard to understand any transmissions however 2 other repeaters I have set up to this radio have a Receive "DPL" and those work fine and receive normal but whenever I use a TPL it has the problem, to clarify its as if something in the transmission is causing the TPL to burst through in very short periods, literally I hear 3-4 bursts per second through, I guess you'd call it, the "pl squelch gate" if you guys can help that would be awesome, thank you
  • 123 Answers
Are you sure that you are using the exact RX Frequency? is the radio in 25Khz if this radio is working on 12.5Khz with the IF filters changed to work in narrow band (12.5) could happend this.
Do you know if the repeater is on parameters mostly of the cases when an over modulation is received this will cut the PL modulation for short periods.
If the radio transmit over modulated could "erease" the PL modulation for short periods.
I think this radios should be checked all the Tune parameters to make sure is ajusted properly.
Good luck
Posted on Dec 18, 2007
2 Suggested Answers
  • 5 Answers
SOURCE: Problem Recieving
First try programming the Receiver for Carrier only Squelch,,ie no PL /TPL, then check if it will receive the repeater OK.
If the audio still cuts in and out then (assuming no fault exist) either you mis-programmed the Frequency slightly, or the TPL choice was incorrect.
There is also a possibility of a Bandwidth mis-programming.
Repeaters may have 12.5 KHz or 25KHz channel bandwidth. Basically if you set your radio to 12.5 KHZ and it receives a transmission from a 25Khz Repeater because of the higher repeater TX Deviation the audio on your radios RX will cut in and out and may sound distorted and very loud as well. Your radios TX would sound OK though, but would have lower audio level when heard on the repeater RX. Does your TX work OK through the TPL repeater?
Posted on Jan 11, 2008
Motorola astro moblie programming !!!!!
"No longer supported" means they don't repair them at their repair depot anymore. However, software for most models is still available. All Motorola software is by subscription, and they choose who can obtain a subscription. You must be a Channel Partner (dealer) or meet their criteria for obtaining it.
Most 800 MHz radios are trunking radios, and require a tower system to operate. Many towers in this bandsplit have been shutdown or retired due to changes in the licensing/availability of 800 MHz frequencies.
If you are planning on operating the radios with a tower system, see the owner of the system for programming. If you are wanting to use the radios in simplex (radio-to-radio), you could get them programmed at a full-line Motorola dealer. You will need to provide your FCC assigned frequencies.
The model number you mention is incomplete, and I could not determine which of the softwares you might need.
Best regards.
Feb 07, 2013 | Motorola Astro Spectra 800mhz Mobile...
My motorola RDU2020 radio receives but does not transmit calls
1) You possibly have a bad or nearly dead battery. Transmit takes more energy than receiving. With this in mind, your radio's transmit will fail, if you have a poorly charged or bad battery, when pressing the PTT. Try a battery from a known good radio to see if it eliminates the problem. If so, replace your battery.
2) The radio is either programmed incorrectly or in need of repair. If you have been experimenting with the programmable features, we suggest you walk back through the steps of programming. Here is a link to the user guide: http://www.mytoolstore.com/motorola/rdx_userguide.pdf Programming instructions begin on page 36.
3) If in need of repair. Radios less than one year old should be under warranty, barring any physical or water damage to the unit. Contact the place of purchase or Motorola for warranty instructions.
If the radio is more than one year old you can get it repaired at any dealer offering Motorola repair. (approx. $85 flat rate)
Best regards.
Jan 12, 2011 | Motorola RDU2020 Two Way Radio
MOTOROLA TWO WAY RADIO GP-63
Go to http://www.batlabs.com/gp68.html the manuals here should get you going. if not find someone with a frequency counter. this is alot easier than getting software for the radio.
Oct 02, 2008 | Radio Communications
RPL & TPL tones used in T-5720
The T5720 user manual does not list the TPL codes possible in the radio. However, they are the standard list, with zero being "open squelch" (no code). Here is a link to a Motorola manual which has a list of the PL codes in order on page 43. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
On the T5720, another item to what for is the Qt noise filter. Be certain to set it to zero unless using the T5720 with others of the same model. It can also block transmissions. Here is a link to a user manual for the T5720 http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
Sep 22, 2008 | Motorola Talkabout T5720 (7 Channels)...
Touchscreen not responding
Hello Cutie,
I would try a master reset it will be your best option, just make sure that you try backing up any informaton to a pc or laptop, or install the motorola phone tools program in a computer and Sync your phone to the pc and then transfer all your numbers, pics and videos or documents u may have stored in there then perform the master reset. Of course if u are having touch screen failure then all this might be a problem. If none of this works for u then you are in trouble because if im not mistaken Motorola has no service repair department, maybe if u call them they may be able to exchange under manufacturers warranty if its under a year.
Good luck..
Jun 08, 2008 | Motorola Mobility A1200
Installing Motorola L6
you will need the motorola phone tools software in order for you to install your phone on the computer. sync is when you want to update the data stored on your computer and the data stored on your phone.
Feb 11, 2008 | Motorola Mobility L6 Cellular Phone
Sending text message
I am having the same problem! I dont know whats wrong! please help!
Jan 03, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Problem Recieving
Dec 17, 2007 | Motorola For MT2000 HT1000 HT6000 GP900...
Problem with the bluetooth on my motorola v3
HOPE THIS HELPS: http://www.motorola.com/mdirect/manuals/V3_9501A42A.pdf
Mar 24, 2007 | Motorola Mobility RAZR V3
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
193 people viewed this question
Top Motorola Radio Communications Experts
Steve
Jose Ma DM.
Jose Ma DM.
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
