Question about Kenmore 71812 / 71814 / 71819 Bottom Freezer Refrigerator
Defrost cycle runs too long and melts the ice in the ice maker. It's a Kenmore 596.73822200. I guess it could be the defrost thermostat or timer but I don't know where they are or how to test them.
    President:
  • 1,197 Answers
We ll see how u need to check the defrost timer....
Before testing the defrost timer, unplug the freezer to avoid an electrical shock hazard.
A mechanical defrost timer controls the defrost cycle of the appliance. In older models, the timer runs continuously and roughly every six hours, shuts off power to the cooling system and sends power to the defrost heater. In newer models the timer advances only when the compressor or defrost cycle is running - an improvement for efficiency. As the timer advances, power to the heating element shuts off and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrost timer is usually found behind the front grill of the freezer. It may also be found behind a cover plate inside the freezer, in the temperature control console, or behind the freezer near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Test the timer for continuity using a multitester. Set the multitester to the ohms setting X1. The timer has four terminals. Locate the common terminal, it should be labeled "3" or "C". If the terminals are not labeled, determine which terminal coincides with the common wire in the connector plug; it is usually the white wire.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multitester should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
Locate the timer switch and turn it clockwise until you hear it click. Now retest the timer as you did above. One pair of terminals should indicate continuity (possibly two pairs). At least one pair should give a reading of infinity. Note however, one of the pairs that showed continuity in the first test should now read infinity and one pair that read infinity should now show continuity. If the defrost timer does not pass these tests, it is likely that it should be replaced.
Before testing the defrost heater, again make sure u unplug the freezer to avoid an electrical shock hazard. The defrost heater is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear or bottom inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. There are three primary types of defrost heater elements; exposed metal rod, metal rod covered with aluminum tape or a wire coil inside a glass tube. All three elements are tested in the same way. The heater is connected by two wires.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Test the heating element for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading somewhere between zero and infinity. If the reading is not between those two extremes the heating element should be replaced.
this is how u check the thermostat..... again Before testing the defrost thermostat, unplug the refrigerator to avoid an electrical shock hazard. Some defrost systems use a thermostat (a bi-metal switch) to prevent the defrost heater from overheating. The switch is normally closed. During a defrost cycle, the defrost heater causes the metal alloy in the switch to warm and as it does it curls back and breaks the circuit. As the metal cools, it makes a circuit again and the defrost heater starts heating again (as long as the defrost timer is in the defrost cycle). A defective thermostat can prevent the defrost heater from coming on or allow it to overheat which could result in heat damage or fire. The panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. On some older top freezers it is necessary to remove the plastic molding to access the freezer floor. Removal of that molding can be tricky -never force it. If you decide to remove it, you do so at your own risk - it is prone to breaking. Try warming it first with a warm, wet towel. The thermostat is connected by two wires. The wires are connected with slip on connectors or a wiring harness. Firmly pull the connectors or harness off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced. Test the thermostat for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading of zero when the thermostat is cold and a reading of infinity when it is warm (40 to 90 degrees F depending on the model). If the thermostat does not pass this test it should be replaced. with regard to the parts incase u need a replacement..... check out the below link.... http://www.repairclinic.com/GE-Freezer-Parts?s=b3a3c221
Posted on Sep 01, 2010
Kenmore elite in door ice maker is not working... 106.5770*701 water dispensor in door works, infrared sensor and on switch seem to be working properly and bin was removed defrosted and replaced and...
Hi and welcome to FixYa, I am Kelly.
Often the reason ice makers slow or stop ice production is because the freezer compartment has gradually warmed up above 17 Deg F and the ice maker thermostat will not start an ice harvest cycle. What causes this gradual warming is usually the result of either an evaporator fan running slow or an automatic defrost circuit problem caused by a fault defrost timer/control defrost heating element or defrost thermostat / thermistor.
You can use this manual to troubleshoot the ice maker:
http://applianceassistant.com/pdf/inDoorIceSystem.pdf
or
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note that jumpering T to H requires the ice maker thermostat to sense a termp of 14 - 16 Deg F for the ice harvest cycle to start. If by jumpering T - H under the ice maker front cover the ice maker does not cycle then either the freezer compartment is too warm or the ice maker thermostat is bad.
If it cycles and does not add water... then the inlet water valve solenoid has failed or the ice maker module is not supplying power to the inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 16, 2011 | Kenmore Refrigerators
My Kenmore no-frost refrigerator is now five-years old and has started to frost over at the inside back of the bottom freezer which makes it run constantly. For the last several weeks I've had to...
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Apr 04, 2011 | Kenmore 18.9 cu. ft. Top Mount...
My GE GSH25JFTC side by side freezer/refrigerator has ice accumlating in the area around the ice maker both above and below the ice maker and in the door shelves in vicinity of the ice maker. It's three...
DEFROST PROBLEM The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad. With an ohm meter it should show continuity when cold and none when warm. You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Sep 11, 2010 | GE GSH25JFT
Power to refrig. Front displays show temp for freezer (0) and refrig.(37). Fan running by coils. Neither will cool. Also the compressor is hot but no humming or other noise
DEFROST PROBLEM
Aug 04, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Not freezing
DEFROST PROBLEM
Jun 01, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The refridgerator portion of my side by side fridge is luke warm. The freezer appears to be working fine. What can I do to fix this?
My guess is, your defrost timer has quit running and ice has built up blocking the passage of cold air from the freezer. It could be the defrost thermostat also, or just a stuck vent door. But I don't think so.
The defrost timer is under the refrigerator, accessible from the front. Normally, it turns on three times per day, turning on a heater element in the freezer, melting ice. The melt water runs down to a plastic tray under the refrigerator where it evaporates. When the freezer warms up, a defrost thermostat then turns off the juice to the heater.
Access the timer from in front. Use a screw driver in the manual advance slot to turn the timer till it clicks. Now it is defrosting. With ice buildup sufficient to block the air passage it may take a long time to melt all that ice.
If you dig into it and try to melt ice yourself, use a hair dryer rather than boiling water. That's what I've been told, although I used the boiling water.
Hope this works for you.
Dec 30, 2009 | Refrigerators
Ice maker stopped making ice
Check this out first. The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 23, 2009 | Kenmore 53542 / 53544 Side by Side...
1 yr old Kenmore fridge (18 cu ft top freezer mdl 970-41924) has very long defrost cycle - freezer contents partially melt, fridge warms to 50-55 F. (Normally runs at 38-40 F.) We keep several litres of...
Either the defrost timer is going out or it could be your defrost bimetal thermostat that is located behind the back wall in your freezer. Both parts are cheap and easy to install. I would replace both.
Sep 09, 2009 | Kenmore Refrigerators
Ice melted and fridge not cold enough kenmore 363.50622000
Several things possible - fan in freezer side not running, defrost thermostat not working, if fan runs and cuts off & on, then the defrost heater strip could be out, but check the defrost timer under fridge; not cycling, you can manually turn to see if fan cuts off and on. If you have "ice shelf" in coils on freezer side then no air circulates in freezer and over into refrigerator side.
Aug 14, 2009 | Kenmore Refrigerators
Kenmore C978-66792-1 fridge: defrost ices and stops fan
It should just be your ice maker wires and wouldn't be the issue with this fridge
Feb 10, 2009 | Kenmore Refrigerators
Kenmore 71812 / 71814 / 71819 Bottom Freezer Refrigerator Logo
293 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
