Question about Garden
How do i replace a track seal in my mini digger please. its a volvo pel job EB 150 1998 type 261 with rubber tracks. Thanks Dave Good
  • 235 Answers
Slack off the track adjuster valve, spin the track off and pull out the idler assy. The seal is on the end of the chrome  piston just pull it out .
Posted on Dec 31, 2009
Takeuchi mini digger tracking problem
Pressure valve? does it only do it to only one side? Left or right. The reason you move both tracks with the bucket running is because you relieve pressure. One side is free wheeling, As they call it. I work on cars, But also have done to many hydraulic components. You have a pressure control valve that is bad.
Jul 10, 2016 | Mini Cars & Trucks
My ex 30 digger is not turning right what could be wrong
Either slew motor or a shuttle valve
Dec 28, 2014 | Garden
Pel job mini digger slew doesnt work but cab can be turned by hand
check for broken drive key /shear pin in the slew drive shaft
Aug 18, 2014 | Garden
Hitachi excavator
Hi I have the same problem,zx16hitatchi mini and I've been told it is track motor needs replacing? Or it could be a seal gone in one side of the spool valve for that track, on the hydraulic pump? Ask a local digger parts dealer for a good repair shop in your area.
Dec 03, 2013 | Hammering
WHAT OIL DO I PUT IN A MITSUBISHI L3E ENGINE FOR PEL-JOB 1.5TON MINI DIGGER?
I have a similar engine in my mini excavator. I would recommend Rotella 15W40.. Good Luck
Aug 18, 2011 | Mitsubishi Lancer Cars & Trucks
Kubota mini digger KX36-2: changing rubber tracks
Undo the nut the nipple fits onto ,thats the valve itself.
Then lift up the machine with the arm over the side that the tracks off  about 2 - 3 foot  so it helps the track to go in and on and start putting the track on at the sprocket end first.
When you get the track to the idler end it will push the grease out as it rolls on or you can lever it home with a big bar before tracking up .
Dec 31, 2009 | Garden
Any idea how to top up hydraulic fluid in old mini digger pel job eb10
Fill it where the hydraulic filter is in the tank .
Nov 15, 2009 | Garden
Digger support
Search local home and garden stores to find a post hole digger. Many department stores sell post hole diggers too. A local greenhouse or tractor supply store is also a good place to look for a post hole digger. Decide on he type of digger you'll need for the job. Although post hole diggers come in different sizes and types, they generally dig the same size hole. Know that it takes a lot of strength to dig holes with a post hole digger, but there are a diggers available with special features that allow someone not quite as strong to use the digger too. Pick up and examine the different post hole diggers while you're shopping. Compare the feel and weight of the tools. Pretend to dig holes and see how it handles. Compare the features and designs of different post hole diggers. Most are manufactured from fiberglass or steel, but some have a different shaped handles for specific digging jobs. Determine if you'd rather have a fiberglass handle or a wooden one. Fiberglass is lighter and more resistent to sun damage than wooden handles. Select a post hole digger based on your preferences, the job required and who'll be using the tool. Plan to spend more on a post hole digger that's made from steel or for heavy duty use. The range for a post hole digger is generally under $50.
Aug 27, 2008 | AMANA TOOL 658060 PRESTIGE FINE DADO SET...
Garden Logo
412 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
