Question about Vacuums
Wet dry vac suction not woking
Was left with water inside possible filter damage? Mold? water coming out blow hole and little to no suction.
  • 57 Answers
The wet and dry vaccuums should normally have the dust filter removed when used for wet work. If the filter was left in, it will certainly be clogged and useless. I would suggest trying the unit with no filter, just to check there is good suction. If there is, a replacement filter is required. If there is still little or no suction, then it is possible that there is a blockage within the impeller area somewhere. Wet dust/dirt tends to stick really well to the impeller blades, reducing their efficiency to point of almost no suction. I'm not sure if you can get that far into your unit, if you can, it would be worth using a stiff brush to remove and adhered debris.
Posted on Dec 18, 2007
  • 75 Answers
Was drywall dust sucked up in it?
Posted on Jan 19, 2008
My hose is on the suction side of the Ridgid Dry Vac but its still blowing out of the other hole. How do I fix this?
it is supposed to blow out the other hole. in order for a vacuum cleaner to suck things up, it also takes in air. That air passes thru a filter leaving the debris inside the canister, and then exits thru the other hole.
Sep 29, 2013 | Vacuums
We inherited the shopvac 16 gallon. I bought the required filter (foam) but the dust blows back from the blow hole. Am I missing a part?
The foam filter is for use when using the vac. to pick up water. Now you should have a paper filter for picking up dry material.If possible you may want to look inside of one at the store. Hope this helps.
Jun 23, 2011 | Shop Vac 925-13 Canister Wet/Dry Vacuum
I bought my first craftsman 9 gallong wet/dry vac - i do not know how to operate it and I don't want to break anything. I have a pamphlet but it is still confusing. can I pour a few gallons of water into...
Hello again.
When it says wet vacuuming, it means that the vacuum will pick up water, not dispense it. When you are using the vacuum to pick up water, you'll need to remove the paper filter element under the motor, inside the canister, to avoid ruining it. When the filter is removed, you will see a plactic ball inside a cage under the motor. It's purpose is to float up on the surface of the water being vacuumed up, and prevent the motor from getting water into it. You'll be able to tell when the canister is full; the noise the vacuum makes will change and sound higher. Also, the suction at the hose will quit. At that point, shut off the vacuum and drain the water.
Be sure to replace the paper filter when you swap back from liquids to solids.
Best regards, --W/D--
Apr 02, 2011 | Craftsman 17026 Wet/Dry Vacuum
I did not get a manual with my vac. I am trying to soak up water from a water tank leak and water seems to go right trough the vac and water is coming out the blower hole. the tub is not full.
There is a special sock that you need to buy for it. You can run the paper filter if your in a pinch but after that one time, that's it, that filter is ruined.
The paper filter is for dry vacuuming, the foam filter is for wet vacuuming, You have to have one or the other in place.
There are two ways to snap the cover onto the basket, only one is the right way.
Look to see that the baffle is facing the hose inlet hole.
Apr 22, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Dewalt dc500 won't **** in water
there is a float ball or reed that closes off the exhaust port inside the canister, to prevent water from filling too high when used as awet vac. If lodged or trapped it will prevent suction or discharge in wet and dry modes. look at the housing that the filter attaches to and you will see it. if it doesnt rattle when you shake the unit up and down, it is stuck; otherwise, you must not be spinning the fan blades.
Jun 23, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
Mar 23, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Suction
There is a float in the water collection chamber that closes off the opening below the filter. Make sure that the float is moving freely and the hole under the filter is not obstructed. Reply if this is not the problem, I have one sitting here that I can look at for other possibilities.
Jan 18, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
283 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
