Canon MP610 Photo All-In-One Printer Logo
Posted on Sep 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot get scanner to work - Canon MP610 Photo All-In-One Printer
Anonymous
Level 2:
  • Expert 137 Answers
  • Posted on Sep 26, 2009
Anonymous
Expert
Level 2:
Answers
137
Questions
0
Helped
40169
Points
392
Try to uninstall and reinstall the drivers.
Be sure that the device is not connected to the computer until the software prompts you to plug it in
How to Fix HP Scanner Not Working Error?
When you replace your latest Windows OS or any other version of the software, your system may not recognize the scanner at times, or confusing messages may occur while scanning anything. At HP Chat Support, our skilled tech-specialists are available to help you resolve your issue quickly and easily. It becomes difficult for the user to determine the root cause of the scanner not working problem.
How to Fix an HP Scanner That Isn't Working
Here are a few methods that may assist you in resolving your HP Scanner not Working. You don't have to test them all if one of them solves the problem; simply work your way down the list one by one.
How To Fix HP Scanner Not Working Issues?
While scanning with the HP scanner, users may face issues. HP scanners, like any other machine, might develop technical problems. These issues can cause your HP scanner to stop working properly. Most of the time, you can easily fix HP scanner not working issues on your own.
For more information, Contact HP Customer Care Support.
If this guide does not resolve your scanner's issue, you may also contact the HP Scanner Support Center via their official website.
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
52helpful
3answers
Driver suitable for CP-HR7X Slim Scanner to work in Windows 7
I can not find driver suitable for scanner CP-HR7X to work in Windows 7 too. I am from Russia.
Umax powerlook III scanner not working with latest mac system sof
Your OS is not compatible. Period. Either go back to what worked for you or get a new scanner that will work in new environment.
Scanner dint work
I purchased Canon DR 9080C scanner two years back but the CapturePerfect 3 not received. So speed is slow. Can Canon Big help me to provide capture perfect 3 software. My email is [email protected]
Scanner has stopped working
When I had the cable that came with the printer connected to the scanner, and the cable that came with the scanner connected to the printer, the scanner didn't work.
Changing the cables changed everything.
2answers
Can't get Scanner to work
hello the scanner wount evevn do enything
im so angry
old marine
old marine
ZJ Limited
ZJ Limited
