Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
9500 stopped spraying water, indicator stopped spinning
    President:
  • 1,653 Answers
Empty the Dirt Container.
Check the Upper Tank for any blockage or dirt build up and clean it.
Clean the Upper Tank Filter.
Clean the Pre Motor Filter.
Clean the Post Motor Filter.
Check that the indicator is not clogged and clean if necessary.
Make sure all the filters are dry before placing them back in the Bissell and using the unit.
Posted on Sep 26, 2009
  • Karl Wright
    Karl Wright Sep 26, 2009
    If all of the above have failed then you either have a blockage in the inner tubing or have a defective water pump and need to replace it.
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Why won't my carpet cleaner spray out water?
Check Water Tank Cap Filter (it looks like a screen). and, check the Flow Indicator Filter (under the Flow Indicator). If that didn't help the try the Bissell Consumer Care at 1-800-237-7691
Aug 25, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 spraying solution but not water
Hey, sorry to hear the spray isn't working on your machine.
Here's a quick link to the complete troubleshooting steps for no spray for your machine.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Feb 13, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell proheat steam cleaner, the 9500 series, and it stopped spraying water. I cleaned out the "gunk" in the heater part, put it back together, and it worked for about 3 min. Then it...
There is probably more gunk in there, the gunk can dry and break off in little shards which can get clogged up.
You can try putting straight vinegar in it, try running it through and let it sit in there for a while to see if it can help loosen up and flush out the gunk.
Oct 17, 2017 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell stops spraying water, carpet not wet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtetrhgd
May 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray soap
Please look at my other posts for this solution
Aug 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat 9500 won't spray water
heatman101
ukyr
Jun 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat cleaner hand cleaner spray but floor cleaner wont
heatman101
cnb,m
Dec 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
18 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
