Question about Car Audio & Video
Im trying to run two kenwood 6/9,s and a mtx sledge hammer 12'' sub of a mtx 6004 amp.where do i put my rca,s front or rear / and if this is poss how do i bridge the sub ????? im lost
  • 31 Answers
Im kind of confused with what exactly your asking. Are you trying to run 3 subs off of an amp? If so, the RCA's should go to the front of the amp, and if your plugging 3 subs in to it, you need to have a 3+ channel amp. There is a way to hook it up differently though. I have 4 12" Hifonics subs running off a 2400 watt Nitro-BMW-486 amp. I just have two subs running to each of the two channels.
Posted on Apr 15, 2010
RCA jacks on kenwood head unit do not function
Just run your amp on the front RCA and tune it on your amp they can blow which sounds like whats happend hope this helps
Mar 18, 2013 | Kenwood Car Audio & Video
Ive got a kenwood kvt-512 n im tryin to hook an amp n subs up but dnt know where to plug my RCA jacks from the amp 2 the radio!
Your unit should have 2 plugs in the back...one for the audio and power wires to connect to your factory connections and the other plug is just RCA connections for your video, subs and front speakers. If you have a 4 channel amp and a amp for your subs, you will have to split the 4 channel amp down to 2 and run them to your front RCA connections. Subs will connect to the sub connections. If yours are not listed then you may have to track down a wiring diagram. Hope this helps.
Jun 12, 2011 | Kenwood KVT-512 Car DVD Player
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
I have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Feb 28, 2010 | MTX Car Audio & Video
Doesn't eject CD! and im unsure how to wire up the two RCA outputs that are lable SUB. and the other lable CENTER! do i really fire up my two 12'' subs, just off one RCA jack? and if so do i run two 6''...
I think you will find that those outputs, SUB, CENTER, must go into an Amp that in turn you plug into, unless they are the ones with inbuilt amps. This depends on the output from your unit though. As to whether it would drive them or not.
Feb 07, 2010 | Kenwood KDC-319 CD Player
Car audio
Most likely the RCA's are running from the sub out on the deck to the amp. You need to run two sets of RCA's for a 4 channel amp. One for the sub out and one to the front or rear channel.
Hope this helps.
May 12, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Help me...
If you had 4 single voice coil speakers you can create either of those 2 ohm or 4 ohm setups. If you run 2 of them in parallel you will get the 4 ohms. If you run 4 of them in parallel you will get the 2 ohms. In parallel I mean that you connect the positives together and run them to the positive on the amp and the connect the negatives together and run them to the negative on the amp. Let me know if you need more help. Good Luck.
-Andrew Hawkins
Jun 24, 2008 | Cadence TXA 6004 4 Channel High Power...
I need help with a system that I just bought.
Well it should be like this...Your amp is prologic which means that it has 5+1 outputs (sub out may be for active sub).Connect your speakers on specific output for each one (center,front left,front right,rear left,rear right and sub).Other devices,CD,tuner...connect to the amp with signal RCA-RCA cabels.On the back of the amp you have all marked inputs.You wasn't specific what do you want to hook?!If you want to hook this "new" to kenwood connect rec out of it to aux in on kenwood.If oposite kenwood rec out to "new" aux in.Hope that this is what you need
Mar 12, 2008 | Audio Players & Recorders
Mtx 895 trouble
check your fuse up front first. some amps will turn the light on with only the remote wire (the 12 volt signal from the head unit). That may be your issue. If not you need to check your signal input. try hooking the rca's to a diffrent source, i.e. other radio your tv anything with Rca out put. If still you get nothing then pull your subs out and take a regular 9 volt battery and touch the leads to the positive and negative of the sub. Just for a moment though if the subs move when they come in contact with the charge from the battery then my last suggestion would be to take it to a store where you can have an authorized tech check out the equiptment. Good luck
Nov 19, 2007 | MTX Thunder 895 Car Audio Amplifier
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
