Question about ASUS P5S800-VM Motherboard
JUST SHUT DOWN
At first it just only restarted, so I'd opted to change the memory. I'm now using a 512Mb PC400 DDRAM. It worked fine but after a month, it started to hang. Just two days ago, it never turned on anymore. I tried removing and putting back all the cables, IDE and power; the peripherals video, modem and memory; and the processor. But still it didn't work. I checked on the capacitors if there is any leaking or busted but couldn't find one. Is there a solution to this?
Please help.
Joey
    Problem Solver:
  • 19 Answers
Power Led Lite? If they don't, then I'm not sure of this.
That DDR SDRAM? PC400? Do you mean PC3200, that's DDR at 400Mhz. If that's the case, the PC3200 may be locked out, or deselected by the system. Why? The system may have found that memory irregular. Try another memory, like PC2700, that's DDR at 333Mhz, that should work in a system rated for PC3200. Check first before trying. Once that memory works, your system should be able to use DDR PC3200 again, I would recommend another memory that what you were using, Different spec from the same Manufacturer or a Different Manufacturer.
Posted on Dec 18, 2007
Does the CPU fan spin when you press the switch? If it doesnt, short the green wire from the power supply with the black one, If the fan still does not spin, the power supply is bad. If it does, the mother board has a problem.
Please get back after this test.
Regards,
Anand
Posted on Dec 17, 2007
Installing two ram( ddr400 512mb and pc400 512mb )
If you are referring to computer RAM always put the largest ram module closest the CPU central processing unit
try to keep the same brand and type of ram the same ie: ddr ddr3.......
you will be able to read the ram type on the ram already inside
make sure you secure the ram modules by pressing the levers down firmly at both ends of of there sockets
make sure your computer is turned of before you attempt this
be sure to wear an earth strap before touching anything inside your computer
the ram modules sockets are located near your cpu
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope this helps you
Mar 21, 2012 | Computers & Internet
RAM Problem in intel D915GLVG mainboard
Most likely the pc400 hynix is incompatible with the mother board, or with the memory you are leaving in place. Try using just the pc400 sticks, if you still get system beeps then you are using incompatible memory. You should go to centon, or other memory manufactures wesbsite and look up what is compatible with the mother board and get that memory for the system. My bet is going to be pc3200 memory.
Hope this helps
Jan 25, 2012 | Intel D915GLVG Motherboard
Shut down when using laptop
Pull the memory stick(s) out of the motherboard and run a single 1x512 in the top slot (under the keyboard) as well as remove the bottom cardslot device as the motherboard had a short causing this on the bottom half (where heat builds up). With these limits (max 512mb and no bottom cardslot usage). It will work great now.
Feb 03, 2010 | Acer Computers & Internet
Can not power up ACER 9410Z laptop after replacing memory
Try to remove one and restart with just one installed,if it restarts,Let it completely load,shut down and reinstall the other one and restart again.
May 31, 2009 | Acer Aspire 3000 Notebook
Blue screen
Simply change your Ram with new one.
Apr 08, 2009 | Computers & Internet
Getting POST Error "Beep" message (3 Long); on a Gateway 500SE Desk Top with an Intel (Nimitz 4000792) P4 1.8Ghz CPU . Can't run machine to ascertain BIOS; thus to determine that manufacture's unique POST...
Dear Frind i think your second ram 512MB Have PC400 Buss Speed, I think also *********** board doesn't support PC400 buss Ram, Please try Ram with PC266 Or PC333 Buss speed. Best Regards sumon
Mar 20, 2009 | Computers & Internet
Ram upgrade problems IBM netvista 6794
You can try this site, it scans your system to see if your computer can run more memory than what is currently installed. it helps you find the right memory modules for your system and and an option for you to read reviews if available and if you want to buy it.
try this site: www.crucial.com
Please rate this solution
Dec 26, 2008 | IBM NetVista PC Desktop
Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Jun 06, 2008 | Asrock K7VM2 Motherboard
Memory upgrade for laptop
Older laptops can be VERY fussy about the memory ... you have to have the exact same 'speed' .. I had a similar problem after trying to upgrade an old machine that took slow memory (PC100) with a FASTER (PC133) module ...
NB> Some VERY old machines would not take 'double sided' modules ... check the manufacturers specs ..
Apr 17, 2008 | Computers & Internet
ASUS P5S800-VM Motherboard Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
