Question about AEG 24 in. Favorit 40260i Built-in Dishwasher
Part way through cycle the cycle stops and the pump continues to run and can only be stopped by disconecting at the power mains
I have a Scotsman CME 506 ice maker. After running a cleaning cycle it won't run. After resetting the freeze light blinks and nothing happens. The water inlet valve never opens (the sump is current
CM3 Operational Sequence.
From Off, push and release the freeze button.
1. If sump is full,water pump starts.If sump is not full,water valve opens to fill it.
2. Compressor starts when sump is full.Air cooled fan motor starts too.
3. water pump stops early in freeze cycle for 30 seconds.
4. Sump refills after pump starts.
5. In low ambient condition,fan motor may begin to cycle on and off.
6. Freeze continues until water level in sump drops to preset point. Exceptions: SCE275 must fill sump two more times.
7. Fan may shut off before the end of freeze.
8. Harvest begins. Hot gas valve opens,pump stops.
9. Pump restarts, inlet water valve opens to fill and overflow the reservoir.
10. Harvest continues for preset first cycle harvest time.
11. If bin is not full, cycle repeats ( compressor stays on). If bin is full, unit shuts off at the end of harvest.
OK with that out of the way unless you unplugged any wires cleaning the machine should not have caused any problems. First cut off water and pull water supply line from water inlet valve look in the end of valve there is a screen in there it could be stopped up. If the valve screen is not stopped up then put supply water line back on and turn water back on. power the CM3 controller off. push freeze button. now with a voltage meter check at the water inlet valve to make sure you are getting power to the valve.If you are then either valve is stopped up or valve is bad. If you are not getting power to valve then replace the CM3 controller now make sure the bin full light is not on because if it is this will not let controller go back to a freeze cycle.
Oct 28, 2014 | Kitchen Appliances - Others
Won't stop filling up. Water continues to flow without stopping for cycles
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Aug 28, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Water continues to run. Will not stop when machine is in the wash cycle.
Good luck, i hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Washing Machines
The water runs in the tub but never stops. Even if you put it on spin to run the water out. The water never stops till it runs over the top of the tub. Is that something in the main control timer that is...
Gene
Jul 29, 2011 | Maytag HAV2557 Top Load Washer
Haywood 1.5hp power-flo matrix pool pump stopped working this morning --I checked and power is getting to timer ---all wires have good connections----pump is 2 years old----does the on/off switch at the...
There is a overload switch - somtimes inside the starter solenoid area.
While you have the pump disconected from mains power - check to see if pump impella turns freely.
Jun 10, 2009 | Hayward 1.5 Hp Northstar High Performance...
Spin cycle not running through stopping at different times eg 5mi
Front loader? Check out your filter & pump for blocks. Belt should be sufficiently tight, play of max half inch. And then check your motor brushes for wear. Power off the wall mains of course.
From the section i am answering this i dont have exact details of machine, but minimum is sufficient. Thats why i ask front loader?
And rate plz............
Mar 26, 2009 | Washing Machines
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
AEG 24 in. Favorit 40260i Built-in Dishwasher Logo
21 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
