Question about DeLonghi D690UX Cool Touch Deluxe Deep Fryer
The deep fryer shuts down after it reaches the desired temp When i plug the deep fryer in and turn it on , the light comes on and the oil starts to heat up , then the light goes out telling me that i am my desired temp and i put ff into the oil and the fryer stops heating up
2 Suggested Answers
  • 83 Answers
SOURCE: What tyoe of oil do you use
What ever cooking oil you prefer!
Posted on Sep 13, 2009
B&S deep fryer heats up to set temp..like 170c, then pilot light turns off.try to relit,no good.if i wait10..20min.I can relit it.but when reach temp,flame goes out again.
The high limit is shutting the fryer off. It is auto reset and that is why the fryer works after waiting. It sounds like the thermostat is not shutting off and the high limit is kicking in. You need to check the actual temperature of the oil.
Aug 05, 2016 | Kitchen Appliances - Others
Turkey fryer won't start
Yo! the Dang pan has to be filled and on the burner which makes contact with the auto shut off sensor that is measuring the temp of the pan. The weight of the filled pan holds that Lil temp sensor down and allows the gas to continuously flow as if you were holding that Lil red button. So after hours of trying to light it without the pan you should find that it does work with the filled pan on the burner holding the red button, stick a match in the hole and let the button go and watch the blue flames flow. My gripe now is that it shuts off after the oil temp reaches 250 to 260 degrees then you have to reignite. Oh yeah my 10lb Turkey was crazy tasty.
Nov 21, 2012 | Brinkmann 815-3786-0 Turkey Fryer
I have an older propane fryer tha will not cut off when desired temp is met. It holds about 2 to 2.5 gallons of oil. I think it is called a table top model. Any solutions?
Sounds like your thermostat is not working correctly. If it doesn't shut down when you reach a desired temperature, then it could be broken.
Are you sure it's actually reaching the desired temperature? You might want to put a thermometer in your oil and read it to make sure your oil is the desired temp before you go to the trouble of replacing your thermostat. If you need a replacement thermostat, we sell them, and you can call us at 888-542-5959. We would need model, and serial if you have it in order to price this part for you.
Thanks,
Susan
Restaurant Equipment Outlet
Cincinnati, Ohio
Dec 04, 2011 | Frymaster Dean SR42G Deep Fryer
Frymaster will not re-light after reaching temp on initial start
You have a lazy thermostat that needs replacing. Not uncommon.
Tom
May 21, 2010 | Frymaster Dean FM345EETC Deep Fryer
Shallow fryer pilot light goes out
Call fafctory service dept 800-637-9188 ext 22
May 27, 2009 | Comstock-Castle 14HF Deep Fryer
I have a ef3 vulcan, when reaches temp, the pilot goes out.
Set the thermostat to 350 degrees,get a thermometer and put it in the oil,when the unit shuts off look at the temp of the oil.If the temp of the oil is higher then the thermostat is bad if not the hi-limit may be.Let me know.
Apr 04, 2009 | Vulcan EF3 Deep Fryer
Pilot goes out when fryer reaches set temp. and shuts-off.
try to change the thermal battery the device that the pilot heats.. other wise there is a screw at the botton of the automatic valve.. try to increase the pilot so it can heat more the thermal battery! u dont have enough voltage to activate the solenoid valve so thats why ur pilot goes off
Mar 09, 2009 | Vulcan GR35 Deep Fryer
Star deep fryer.
Those thermostat bulbs are the thermostat and hi-limit bulbs.They need to be secured to the fryer.The hi limit is tripping out because its sensing that the oil is too hot.Even though the oil isnt that hot the hi limit thinks it is.
May 15, 2008 | Star 530FD Deep Fryer
Garland deep fryer
gas valve not fully turned on
cattering hose not fully pushed into connector
thermostat tube inside oven broken (new valve)
Nov 13, 2007 | Garland AF-5025 Deep Fryer
Problems with fryer
your problem is the thermostat is bad.the reason it shuts down is that it trips the hi limit.the hi limit is a saftey device that shuts the system down so the oil doesnt get too hot and catch on fire.remove all the oil from the tank and you should see 2 skinny metal bulbs one is the hi limit bulb the other is the t-stat bulb,make sure they are secured to the bracket.if the t-stat bulb isnt you will also have this issue,simply reattach it.let me know.
Nov 10, 2007 | Imperial IFS40 Deep Fryer
DeLonghi D690UX Cool Touch Deluxe Deep Fryer Logo
76 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Shehu Pro
Shehu Pro
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
