Question about Olevia 237T 37 in. LCD TV
I have an Olevia 237 T12 LDD HDT I'm having a problem turning it on from the remote and the power button, what can I do?
ki4kmn
  • 7 Answers
SOURCE: no picture no sound
After taking the screws out and removing the back, you will see a power supply(where master switch and cord connector are). Remove the 4 screws on the aluminum cover plate to gain access to the fuse. Using a voltmeter, with the power on and switch on, measure the voltage on each side of the round fuse located just behind the cord connector. If voltage is 0, fuse is good. If voltage between 115 and 125 V, replace fuse or have fuse replaced. I think it is a 6.3Ah 250V class fuse that is soldered into the board. IF YOU ARE NOT FAMILIAR WITH SOLDERING TECHNIQUES AND PRECAUTIONS, DO NOT ATTEMPT TO DO THIS. IF YOU ARE NOT FULLY AWARE OF ALL SAFETY PRECAUTIONS NECESSARY TO MAKE THIS REPAIR HAVE A QUALIFIED TECHNICIAN DO IT FOR YOU!!!!!!
Posted on Apr 07, 2009
SOURCE: Need code for my Cox Remote Control for my 26-inch Olevia 226 T12
We had this same problem as well and we finally found the answer, the code for the COX remote (silver on top black on bottom) is 1240.
Posted on Aug 29, 2010
Testimonial: "Thank you, Leppar, Thank you for your solution to my problem. Now I don't have to mess with two remote controls to operate the TV. "
budmrtn
  • 11361 Answers
SOURCE: My olevia 237-t12 won't turn
It may abe in the safety shutdown mode due to short circuits in the power supply or in the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Sep 07, 2010
SOURCE: I have an Olevia 237-t12 hdtv, I will lose the
I had the same problem with the exact same TV. I took it to a local TV shop. My problem was fixed by replacing the T-Con controller board. The cost of the part was about $85 and labor $125. There are no "new" parts out there for Olevias because the company is out of business but I did find a part pulled from a "damaged in transit" TV. It's a personal decision (assuming the parts can be found) as to if its cost effective to repair the TV.
Posted on Sep 15, 2010
techman007
  • 1112 Answers
SOURCE: Olevia 237-T12 loses signal or just goes black.
Replace the power supply.
Posted on Sep 18, 2010
Where is the fuse for power located on a 42in olevia 237-t12 tv
At it main power regulator board inside. If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 24, 2017 | Olevia Televison & Video
My olevia tv 237-T12 turns on but has no picture or sound. Screen is on but blank screen. What can I do to fix this problem
to save money take it in for a proper diagnosis and quote
that saves you chasing problems that may cost more than a shop repair or unit replacement
Sep 16, 2016 | Olevia Televison & Video
What mode must i b in to program an universal remote to model 237-T12 with just an outside digital antenna connection
Your RCA remote has a code search feature you can use to find a suitable code. If a search through all codes stored in the remote produces no result, you may have to try a different programmable remote.
Jan 05, 2015 | Olevia 237T 37 in. LCD TV
Where can I find stand for Olevia 237-t12
Hello; I would try Jimmy's parts dot com. He has tons of stuff. You can also contact Olevia for the part, but it will probably be more expensive. John
Nov 22, 2010 | Olevia 237T 37 in. LCD TV
I need the 3 digit programing code for my 237-t12
Here is a link that contains most remote codes.
http://www.thompsontv.com/rcarc.html
You should be able to find what you need there.
Feb 18, 2010 | Olevia 237T 37 in. LCD TV
Olevia 237 t12 has hummmmmmmm in the sound
Does the hum go away when you mute or turn down the sound completely? If it does then the issue might be one of the sources connected to it IE: DVD, Cable Box, Satellite receiver..
Nov 17, 2009 | Olevia 237T 37 in. LCD TV
Remote control codes
Go to Best Buy and buy the DirectTV Universal Remote Control ($20 and works with all cable and satellite services) Model RC64. It will control all the functions on the Olevia TV and Satellite box, except the A-B-C-D buttons for the User Guide.
The remote codes are:
RCA Satellite Box - 00392
Olevia 237-T12 - 11610
Enjoy
Nick from Ft. Myers
Feb 08, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 237T 37 in. LCD TV Logo
29 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
