Question about Acer CU-6530 Digital Camera
Acer CU-6530 digital camera on display it says this card can not be used. no shot, no video recording no display in memory contents
When I try to shoot a video, it automatically cuts off after 23 seconds
When a green light on the back is flashing, it is not the battery light, it is the memory access light. When the buffer is full, the camera will stop the recording, and save the content of the buffer to the memory card. During the writing, the green light is burning, or flashing. If you want to make longer shots, you should buy a faster SD card.for Video, you should have at least a C10 card, but better a U1 or more.
Feb 09, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Camera freezes , battery isn't flat , please wait whilst finishes recording message is sometimes displayed
Looks you have a slow memory card. Nothing wrong, when you use class 2, 4 or 6 in your camera, but it will slow things down sometimes. Not only for sports shooting, 5 or more frames a second, you need a fast card. For Video it is advised to chose fast cards to. Some cameras only manage one shot a second, and that will become word, when a slow memory card is in the camera.
I don't say this is the reason, I only say this could be the reason.
Dec 27, 2013 | Nikon COOLPIX P520 Digital Camera Black...
How do I download contents of a memory card in my Cyber Shot DSC-W55 camera to my Mac?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo/video cataloging program, such as iPhoto for photos and iMovie for videos.
Mar 23, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
Hi I plug in my Cybershot Sony camera on to my computer using a USB cable, strenge files get displayed.....the contents of the memory card: images & videos dont get displayed. it doesnt even give...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 08, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Canon powershot SD1000 video playback problems
Unfortunately, no. Time-lapse video works by taking fewer frames and then displaying them at normal speed so as to give the impression of time going by faster than in reality. Thus, the camera simply hasn't recorded all the information it would have in normal mode, and there's no way to recreate that information. Think of reading just the first line of every page of a book: you'd get through it quickly, but you'd also miss some things.
Now, if you'd shot in slow-motion, then you could throw out some frames until you got to normal speed.
Jul 26, 2010 | Canon PowerShot G9 Digital Camera
How do you get pictures from internal memory to memory card on
First, insert a compatible memory stick in the Camera then turn the Camera ON.
Then, press the Menu button to display menu items.
Then, use the control button to select Setup option.
Next, select Memory stick Tools > Copy.
This will initiate copying contents from the internal memory to the memory stick inserted in the Camera.
Oct 16, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
I cant put a 2gb digital card
hi
check out your fullfill there instructions
  • Supply voltage: 2.7V-3.6V
  • Durability: >10,000 insertion / removal cycles
  • Supports Content Protection for Recordable Media (CPRM) for music and other commercial media
  • Fully compatible with SD Card Association memory card specification standards V1.1
  • if yes ,
    try to format in fat file system with your pc or format with camera
    Aug 10, 2009 | Acer Cameras
    My digital video camcorder mv700 displays a black screen on record mode.now when operating in play mode it displays no card.please inform me of nearest service canon centre.
    Have you accidentally switched on the view-finder? In this case the LCD screen will automatically switch off (usually to save battery power)
    Also have you accidentally switched your camera to still-shot camera mode, or something else, so the camera asks for the memory card in playback?
    Jul 09, 2009 | Canon Video Cameras
    "Recording stopped. Record in internal memory "
    This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures
    Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
    "Recording stopped. Record in internal memory"
    This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Acer CU-6530 Digital Camera Logo
    103 people viewed this question
    Top Acer Cameras Experts
    Joseph Hoffmann
    Are you an Acer Camera Expert? Answer questions, earn points and help others
