Question about Brother MFC-5840CN All-In-One InkJet Printer
SOURCE: user's guide- trouble shooting and routine maintenance
printer will not print referring me to the trouble shooting and maintenance chapter in the manual which I can't find......I have a Brothers MFC-420cn CAN YOU HELP ME......
Posted on Feb 05, 2008
SOURCE: UNABLE TO PRINT
press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
machine will be in maintenance mode and lights will flash.
press start bk copy in case machine wont directly display the error code.
Error starting with 4 means defective print head.
Error starting with 5 menas defective purge station or cycle problems.
both error series means: you need a new printer...
Posted on Feb 13, 2008
SOURCE: "Unable to clean see trouble shooting and routine maintenance"
you should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge
counter is already full. Please refer below for the instructions on troubleshooting
your machine.
1. To enter MAINTENANCE Mode: Press
MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the
following:
a. 8 then
press SET
b. 0 then
press SET
3. Using MONO START, just press it until
the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the
following:
a. 2 then
press SET
b. 7 then
press SET
a. 8 then
press SET
b. 3 then
press SET
This is to reset the purge
counter. Then press stop/exit
5. Using arrow up button look for the
following:
a. 0 then
press SET
b. 1 then
press SET (To reset unit)
a. 9 then
press SET
b. 9 then
press SET (To exit Maintenance mode)
Posted on Jul 11, 2009
SOURCE: clean unable 46, See Trouble shooting and routine
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
email me if I help you. . ryuuzaki182@gmail.com
Posted on Mar 26, 2010
SOURCE: see troubleshooting and routine maintenance
Error 46 in my printer brother DCP-165-C any help please
Posted on Feb 12, 2011
Mar 22, 2014 | Brother DCP 165C Compact Color Inkjet...
Jan 30, 2011 | Brother Multi-Function Center® MFC-215C...
Jun 09, 2010 | Brother MFC-5840CN All-In-One InkJet...
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Feb 18, 2010 | Brother MFC-5440CN All-In-One InkJet...
Aug 14, 2009 | Office Equipment & Supplies
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Oct 02, 2008 | Office Equipment & Supplies
Jul 04, 2008 | Brother MFC-3240C All-In-One InkJet...
Jun 30, 2016 | Brother MFC-5840CN All-In-One InkJet...
15 people viewed this question
Have you tried to unplug the printer for 1 minute then plug it back in?
