Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
How to change oil on 1.5 hp,2 gal. air compressor
    President:
  • 1,167 Answers
Run the machine until it fills up then unscrew drain plug on front or underneith pump unit once drain replace plug and unscrew filler plug and fill with oil till it comes 1/2 full on sight glass or touches line on dipstick done
Posted on Sep 26, 2009
ollie reece
  • 1167 Answers
SOURCE: Compressor tank will not fill with air
piston rings gone valves stuck inside nonreturn valve jammed the pipe coming from the pump unit into the tank before it goes into the tank it goes to a gold valve you need to take this out and check the rubber and spring if the seem ok turn it around and put back in then get back to me buddy
Posted on Sep 16, 2009
  • 1383 Answers
SOURCE: type of oil
Air compressor pumps can use different grades of oil depending on weather conditions and usage, however do not use engine oil. Some Ingersol Rand pumps use a synthetic oil available through WWGrainger on the web. (generally not model specific) If this pump is lightly used you can use the less expensive compressor oil sold at Lowes lumber made by Campbel Hausfeld. It sells for less than $3.00 a bottle. Generally speaking, under normal weather conditions and light duty use, do not worry about the weight of the oil; just make sure that it stays clean and at the right level. If your compressor is running hot, it may be due to other problems like the check valve, head gaskets leaking between cylinders or chambers or high usage. If, however you just want the best oil for your compressor, use the synthetic. It is usually colored blue or green. This oil is special formulation to prevent breakdown in high heat and will not allow carbon for form on parts or inside of the hoses. enjoy
Posted on Nov 29, 2008
  • 5 Answers
SOURCE: how long should it take to fill up 80 gal tank
10 to 13 minutes from 0 psi to max and auto-shutoff. Tank will be extremely hot, also. Hope this helps!
Posted on Jul 15, 2009
  • 98 Answers
SOURCE: where do i find the Owners Manual or Service
Its best to use a 30wt non detergant
Posted on Jul 21, 2009
  • 41 Answers
SOURCE: central pneumatic 2 hp 4 gal air compressor has
can you please tell me where are the leak found as there are different place with dif temp seal
Posted on Sep 27, 2009
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    What kind of oil do i need for a craftman 1 hp 3 gal 125 psi compressor m/ n 921 153101?..
    For warm climate, use 30wt non detergent oil (lowest price $3). Med priced oil ($5), use compessor oil sold at Lowes or any major center store including Wal Mart. Compressor oil is special blend for higher temperature range (continuous use). High price oil, synthetic compressor oil works for heavy duty use under severe conditions (also sold at major lumber centers, cost about $8~18).
    For lite duty, any oil that you have handy will work fine (check oil before every use). Good luck
    Oct 03, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    I have a 3 gal 1 hp air compressor and it will only build pressure to 27 lbs.
    If it makes hesitation sounds just before shutting off, you need to oil the compressor as per the manual. This is the most common problem.
    If it is kicking on and off normally, you need to adjust the pressure relay. The instructions are under the cover.
    May 14, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
    I want to change my EMGLO D55155 compressor oil. What type and how much oil should I use? Thank you!
    The compressor tanks 4 ounces of oil.
    You want to use a synthetic oil in this unit. We like to use Mobil 1 full synthetic 10w30 oil.
    Here is a link top the owners manual:
    http://shoppingcart.msservicecompany.com/msservice_net/product_files/D55155/D55155_OM.pdf
    Oct 07, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
    How do I and how often do I change the 2 stage oil?
    only if its dirty, but how often is the compresor runing in a week?
    if you change the oil once a year thats fine,,,just keep it toped up
    Oct 28, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
    The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
    Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
    286 people viewed this question
    Top Craftsman Air Tools & Compressors Experts
    John Trevino
    JOHN LAPIER
    Joe Garcia
    Joe Garcia
    Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
