F04 error message on a bosch exxcel 1400 washing machine, then the water wont drain away
  • 1,031 Answers
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Posted on Sep 26, 2009
  • Washing Mach... Master
  • 909 Answers
Most logical step is to remove drain motor then clean area at the impeller. replace and test.
  • Daveroe Dec 08, 2010
    Cleaned out the impeller area, but found the problem was in the outlet pipe to the waste, lots of fluff and debris has accumulated or grown in the pipe over the years and clogged it. By bending it this dislodged the debis, ran a rinse cycle into a basin and that cured the problem.
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
Have a Bosch Exxcel - error code F04 comes up half way through cycle - cleaned filter...still not resolved. Any ideas?
washing machin pipes were frozen in garage, defrosted now. done one wash half way through, error f04 came up. water still in machine and it makes a noise when trying to spin. The fillter knob has broken and i can't undo it to clean it out.
Oct 15, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
I keep getting error message F04 on my BOSCH exxcel 1400 express washing machine. What does this message mean and how can I fix it?
  1. Loose debris blockin pump - Clean drain pump on the bottom of the machine,
  2. Drainage pipe and or drainage hose blocked - I would like help on this as well.
Mar 01, 2009 | Bosch Washing Machines
Bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
May 26, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Washing Machine Will Not Drain
you have got a blocked filter or pump the filter is located on the right hand side at the front of the machine down the bottom behind the plinth you can drain the water from there as well by pulling the small grey hose out pull the plug out of the end and place in a small bowl good luck when the water is out you can check the pump impeler as well clean the filter houseing and put it back all should b well unplug the machine b4 u start work
Sep 02, 2007 | Washing Machines
Bosch Exxcel WFX2467
try removing power from unit and re-applying about 15 minutes later
May 13, 2007 | Bosch Exxcel WFX 2467 Front Load Washer
Washing Machines Logo
1,613 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
