Question about Garden
Simplicty zero turn 18 hp will run about 15mins shut down will not even click fof about 30sec to 1min then start run for 3mins and then shuts down same no click 30 to 60 sec then starts
  • 472 Answers
That is some thing that i would hsve to see to fix
Posted on Oct 01, 2009
My dehumidifier doesn't stop even if you turn the knob down to zero
Turn the knob the other way - you are most likely setting the target humidity closer to zero, which would cause it to run more (or constantly).
At a higher target humidity it will run less. You should hear a distinct click as you turn it higher - that is the current humidity in the room, and the compressor will shut off. The fan may run a little while longer, but should shut off as well in a few minutes.
Good luck and please rate this answer 4 stars if helpful.
Oct 25, 2017 | Dehumidifiers
I have a White Rodgers 50E47-843 Ignition control, my gas furnace gets the call for heat and the exhaust fan starts and runs for 1 min before the LED lights yellow for 2 seconds and then starts the hot...
A certain sequence of events has to occur to start normal operation. My furnace would start the stack blower which would then run forever without the furnace starting up. The service tech replaced the stack blower controller and the ignitor to get things running right again. Remember that some stages of startup are temperature dependent. For example, the burner has to heat the bonnet enough to close a thermal switch and turn on the main.blower.
Oct 26, 2013 | Heating & Cooling
Turn zero
sorry but i would talk to the shop about that.
Jul 30, 2013 | Ariens Zoom 42 In 165 HP Briggs Stratton...
I HAVE AKAI PT50DL24XISMS IT COMES ON FOR 30SEC TO 1MIN THE PICTUREGOES OUT THE SOUND STAY ON THEN GOES OFF
Its a DLP that uses a lamp, lamp is possible but I would also look to see if fans are on and running, a fan stopping or even slowing down can trigger the set off also.
Average lamp life is 2000 hours or two years and set if lamp a bit dim may shut set off.
Dec 18, 2012 | Akai PT5598HD 55" Rear Projection...
Hp g72-260us suddenly shuts down on battery power only
your power setting is not work perfectly going to your battery option and click that then you setting power capability.
Feb 17, 2012 | HP Audio Players & Recorders
Console won't eject disc or shut down
Same thing happened to me a while back. First try unplugging the Wii for 30sec-1min. Then plug it back in, turn it on, and then hold the eject button for 10 seconds. If that doesn't work try it again with the Wii in a different position. (Horizontal instead of vertical or vice-versa). If that doesn't work it might be a disc drive problem and it might have to be sent to nintendo.
http://www.nintendo.com/consumer/webform.jsp
This is their service site. Hope it helps!
Mar 02, 2011 | Nintendo Wii Console
Ink system failure, everything was fine, i put new ink in just like i have many times before and now it won't print anything, it keeps telling me ink system failure on the monitor
This error usually means you are at the end of the life on the printhead or the printhead assembly has a defect causing it to stop working. You can try removing all of the cartridges with the machine on. once they have all been removed unplug the power cord from the socket (be sure printer is still on!) wait about 30sec-1min. then plug back in. the display will Read out of ink install and an icon for each missing color. Reinstall all cartridges and close cover. it will take a minute or 2 for it to cycle and prime the ink. The display should read ink Sysytem Failure, power down machine. Press Power button to shut down, leave for another 30sec. and then turn back on. If the error displays again you will have to contact HP for in warranty service or replacement options. Note: if you are out of Warranty it is a good idea to shop for a new printer via Costco, Walmart, or an Office Supply Store, it will save you $$$
(a friend had this issue and they were going to sell her a new printer for $30 more than staples plus shipping!)
Feb 18, 2011 | HP Photosmart C7280 Printer
Fuel
Since this seems like a fuel shortage problem amplified by slosh, it could also be the purge valve after the charcoal canister, that is supposed to let air in and out of the gas tank. Open the gas cap and listen for a "whoosh" when it is happening. There is not supposed to be any pressure difference.
Jul 11, 2010 | 1999 Chevrolet Silverado 1500
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
