Question about Saniflo 002/003/005 Saniplus Toilet with Macerator Series Pump in White Rou
It won't stop running
The pump will not stop running unless I unplug it
  • 33 Answers
Good that you unplugged it. Now clean it thoroughly. that means clean and acid descale. also check 22mm outlet AND pipework for blockages. Saniflo sell their own cleaning solution. The reason that the saniflo keeps running is that the soil / scale interferes with the normal operation of the float switch. If cleaning doesnt solve your problem then it could be time for a new switch, but as these unit tend to fail in the off position (i.e. fail to operate ON) this is unlikely.
Posted on May 10, 2010
  • 38 Answers
Sounds like the float switch is hung up or burnt out. hope this helps. duane.
Posted on Oct 04, 2009
Water pump shorted out. Now will not stop running unless washer is unplugged
oops you shorted the control board and now it needs more fixing at more expense
Jul 13, 2016 | Kenmore Elite Oasis 27052 Top Load Washer
97 dodge fuel pump
The pump will only run for 1 second unless the engine is either being cranked or is started and running.
May 02, 2014 | Dodge Pickup Cars & Trucks
Drain pump wont stop
It sounds and look's like the pressure switch. Their should be a tube connected to the pump that travels to the top of the machine ! ?
It could be more expensive (e.g timer) but check that you can blow through this tube from the pump to the pressure switch, a very slim tube about 7mm. Hope this helps ?
Jan 21, 2014 | Amana Washing Machines
Asko 20.1 won't stop pumping unless I turn it off at the wall switch.
this happened to my D3111 and, sure enough, there was a split in the water outlet hose and the water overflow raised the polystyrene float block.
6 months later th same symptoms occurred but the inner base was dry. I took off the lower front panel under the door and found the water level (3 terminal) microswitch had burnt out, probably from running too long. Easy to replace if you can hunt down the $2 switch (brand name Zippy, 6 AMP)
Nov 16, 2012 | Dishwashers
My van sedona 2005 after i stop it,it won't restart unless i press a few time on the gas pedal ,and also runs rough a bit what could be the cause of it.
May be the starter or fuel pump. Might not be getting gas after turning it off. the gas may be settling to fast into the fuel pump and none staying in the engine. My friends SUV does not start unless you pump the gas pedal. Not an expert but its what i know it could possibly be.
Apr 23, 2012 | 2005 Kia Sedona
My maytag neptune MDE5500AYW will not stop unless it is unplugged
if you have it on time dry and it counts down but won't shut off you most likely have a bad computer board,part number 33003028 and it's around 180 dollars.on older machines it would be a problem with the timer not going to off but you have a computer board in your machine and it takes the place of the timer and other functions,just about everything runs through the computer board.
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Coming to stop sign by putting break gear slips then return to park move to drive runs. second as i drive in curves slips but as give gas enough continues running.
Just to make sure I got this right. If you come to a stop, the car won't pull again unless you put it in park? Then, if you start into a curve, the transmission starts to slip unless you give it more gas? This could be signs of a bad torque converter, failing fluid pump (not as likely), or burnt/low transmission fluid level. Check the transmission fluid after the vehicle has been driven (warm engine), leave it running, and on a level surface. Check the level twice and take the lowest reading.
Dec 29, 2011 | 1993 Pontiac Bonneville
My Neptune washer MAH6700AWW won't unlock door and won't work. It stopped mid cycle and the door is in locked position. I unplugged and replugged and try to run a cycle but all it does is make...
Hi
It seems that something is clogged in the drain pump assembly and you have to clean it to solve this issue. After cleaning if the issue returns then test the door lock assembly, if bad it should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 07, 2011 | Washing Machines
Honda 2001 ex stopped running and steering locked up
you say stopped running steering locked up the steering lock is mechanical and has nothing to do with the actually running of the engine so i am presumming that the car was idling stalled on its own and the steering as you tried to restart it locked or the steering won,t turn it won,t if the engine s not running as it is helped by the power steering pump which doesn,t work unless then engines running but if the steering has just locked up then you won,t be able to turn the steering in which case you,ll need a new steering lock not that big a job yates210456
Jul 20, 2008 | 2001 Honda Accord
Saniflo 002/003/005 Saniplus Toilet with Macerator Series Pump in White Rou Logo
852 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
