Question about Garmin Edge 305 GPS Receiver
The unit shows no signs of life, when i plug it in to charge it does not indicate that it is charging, it will not turn on
  • pedrogilcost Sep 27, 2009
    I have the same problem.
    Do you have solution?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Try soft reset :
hold lap/reset and mode buttons for ten seconds, then release and wait 10sec, then hold start button for 10 seconds, device should start
Posted on Sep 10, 2010
Why won't my phone show any signs of life
needs the battery replaced possibly
Oct 21, 2015 | Samsung Cell Phones
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
May 14, 2012 | Lenovo IdeaPad Z560 Notebook
Brand new Garmin Nuvi 1490 T out of the box. How do I charge it? The only devices in box were a car charger (my commute is 5 minutes daily) and a USB connector? Should I just plug the USB into my computer?...
Garmin satnavs come with a charge out of the box.
In some cases your device may have lost a charge during shelf life. In this case you can charge these units in three ways:
  1. Place unit on computer with USB cable for approximately 8-12 hours
  2. Place unit on Garmin specified AC adaptor for approximately 4-6 hours
  3. Place unit on 12V vehicle adaptor for approximately 4-6 hours.
Some cars continue to supply power to the cigarette lighter socket when turned off and others don't. If yours doesn't you can charge it from your computer. There's no indicator to show that it's charging or when it's charged. However when you disconnect the satnav from the computer and turn it on there's a battery state indicator which shows if it's fully charged or not.
Aug 16, 2010 | Garmin nuvi 1490T GPS Receiver
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
The battery status indicator does not show on my screen. I can only see it when I first turn on using battery power. It doesn't show me anything when it's charging, or how much battery life I have left.
The indicator goes away telling you that its no longer running on battery power and that its running on the car or AC charger. During that time, its charging the battery. Only when you remove the unit from the charger/adapter will you see the battery icon because you will then be on battery power. 4 green bars mean you are near or fully charged.
- Jim
SHARCNET-USA
Oct 07, 2009 | Garmin nuvi 265 Car GPS Receiver
Inspiron runs on ac power but not battery
Sounds like you have a faulty ac adapter or jack on the laptop and its not charging the battery fully. More like a trickle charge. I would recommend leaving the laptop on default power settings or the best power settings and see if their is a differance in life or either shutdown the laptop and let it charge until the light shows fully charged.
Jul 20, 2009 | Dell Inspiron 1501 Notebook
Help!
Turn on your garmin out of the car, connect to a PC via USB cable and see if the battery indicator goes away. If it does then the USB to PC cable is working and charging the unit. To test the car adapter, you can unscrew the tip of the plug to examine the fuse. Most Garmin car charger units have a light on them that ilimunates when you plug it in and turn the ignition. It could be that the plug is just loose in the socket. The picture shows the unit running on battery. If you plug in the usb cable and this indicator goes away, then it should be charging.
Jul 25, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin Edge 305 GPS Receiver Logo
227 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
