Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman Tractor Battery wont charge 917271011
I have the same problem as mentioned before, checked the fuse (30a) and have replaced the battery every 6 weeks because of this problem so I know its not a bad cell. anything else I can check?
    President:
  • 1,653 Answers
With the mower off, disconnect the battery from the mower and place a voltmeter on the battery terminals and check the voltage. This should be well above 12dc and the higher the better. Ideally something like 13.5 Vdc.
Reconnect the battery and switch on the mower and then check the battery voltage again at idle. This should be above 12Vdc and should be in the region of 12.5Vdc to 13Vdc.
Now rev the engine while stationary and check the voltage again. This should be significantly higher that it was when the mower was on idle or switched off. This should be somewhere between 13 and 16Vdc If not then the alternator is defective and if you have a charging circuit regulator unit fitted this may be defective.
If the voltage is considerably better than when the mower was on idle or switched off then there should be no problem with the charging circuit.
If you have changed batteries that often are the ones you are replacing it with of the correct capacity and CCA Cold Crank rating? If not then these can degrade very quickly. What I do with my mowers is to take the recommended rating and add up to 10% for the nominal and CCA currents and these just go on and on! Don’t be tempted to increase the capacities any further because the charging circuit will never be able to cope with the battery demand.
Posted on Sep 26, 2009
I need to check electrical system in my riding mower
Check your battery cables all ends. and see if they are loose or corroded. Just an Idea. Check all fuses if you have any.
Dec 07, 2016 | Craftsman Garden
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Battery dies on 03 yamaha after being ridden, battery wont hold charge..have replaced battery, stator, and regulator. wiring harness problem?
no not wiring harness! Unless the stator connector is unplugged.
check to make sure the charging fuse is not blown. Should be a 20A or 30A fuse.
When the bike is running test the battery to see if it is charging, should be between 13.25 volts and 14.5 volts.
Apr 04, 2014 | 1999 Yamaha TDM 850
Craftsman garden tractor Mod # 917.257740 blows main fuse.
Try checking the battery - make sure it is not under rated - over rated and be sure the starter it's self isn't drawing too much amperage.
the battery may need replacing and for a temp fix - put in a larger fuse - say 50 amp.
Thanks for choosing FIX Ya
Gary @ Fix Ya
Jul 06, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Transaxel broke & I replaced with new. Now engine won't start, just clicks. Battery is charged. Ran fine until axel broke
check the wiring under rider possible hit and disconnected or damaged wiring also check connections at battery -also check fuse by solenoid and solenoid
Jun 09, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Battery will not charge
IS THE BATTERY GOOD,IF THE BATTERY IS BAD IT WONT CHARGE IT,IF ITS GOOD THERE SHOULD BE A 20 AMP FUSE FOR THE GHARGEING SYSTEM
Mar 24, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 24 kohler engine
there is no alternator on small engines it is called a stater which is usually on the coil all one unit with coil but does the battery charge on a battery charger the battery might be bad & wont take a charge let me know if i can further help thanks wade
Jul 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Jun 07, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Replaced battery for lawn tractor and nothing happens.
You probably just blew the fuse behind the ignition or the fuse link on the power to solenoid.
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
698 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
