Question about Dell Dimension 5100 (D51L1) PC Desktop
Hello, the green motherboard light on the computer
Hello, the green motherboard light on the tower of our Dell Dimension 5100 desktop flashes Green every 3 minutes. I never noticed this happening before and wonder if this is a problem?
  • 137 Answers
If there is no loss of functionality then I would say no.
Posted on Sep 26, 2009
On powerup of Dell Dimension 5100 running Windows XP the computer hangs with diagnostic lights 1, 2 and 3 a steady green and 4 off. The onscreen message is: 300XT BIOS P.N 113-A33437-102 which appears on a...
try this:
Power the PC off, open the case cover, remove/reseat the video card in the slot.
* Power the PC off
* Disconnect the PC power cord from the rear of the PC
* Remove the computer cover
* Move the RTCRST (Clear CMOS) jumper from pins 1/2 and place it on pins 2/3
* Press the PC power button
* Move the jumper back to pins 1/2
* Remove/reseat the video card in the slot
* Replace the power cord and cover and then power the PC on
Hope it helps
Nov 05, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Amber light flashing on my dell 5100, green light on motherboard
The green light just means it is plugged in and getting power.Try pulling the plug, the green light will go out. If you can remove the battery out of the motherboard, "it looks like a quarter", leaveit out for a couple minutes and out it in 'The same way it was" make sure you "look" at it before removing it, it has a little release thatenables it to lock in, or pop out. plug it in and give it a start. It may just be the settings got corrupted, that little battery saves the start settings, once it starts, we can go into the bios if any settings need changing, I'll keep an eye on this post, good luck
Mar 16, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Powering up
cleaning wont help you have to get a new motherboard
Sep 18, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
No video
Try to check the light on the monitor. If it is amber, then check the video cable both from the back of the monitor and the tower. Try a known-good monitor. Check the diagnostic LEDS of the tower. There are four of them in the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem. If you have a solid green light on the tower, no beeps heard and no video, check the LEDS. If you get 2-4 light, a possible graphics card failure has occurred. If the computer has an external graphics card, open the tower, remove the card and put it back in. If still persist, try a known-good card. If it still does not resolve the problem, try reseating the memory cards. Remove and put it back in. If still no go. Then it's a motherboard problem.
Sep 16, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
Sep 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computer won't start
Can you see a green light on located on the mother board ? I had the same problem with mine right after the warrranty was off, The mother board failed, But you should make sure thats it first by making sure everything Inside of the computer is tight and secure.Unplug and make sure there is no power on and unplugged,Before you touch anything inside your computer discharge any static electricity by touching the metal on the inside of the tower. The Memory modules Make sure that they are pushed in securely in there slots and video card is Pushed in and tight, and any other extras you may have plugged into it, After you do all that put everything back and try to reboot see if that get you up and going. If not let me know I can Help You fix it or repair it myself if you would like, just leave message here or email me. bear350cid@yahoo.com Happy Holidays
Dec 15, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
128 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
