Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I have a blinking snowflake icon on my air conditioner, my air will not work. My heater will work fine but the air will not come on
  • Honeywell Expert
  • 252 Answers
When the snowflake is blinking the thermostat in in a delay mode designed to protect your compressor. If it does not stop blinking in 15min the stat is bad otherwise something is wrong with the AC
Posted on Sep 26, 2009
  • 4 Answers
I have 2 identical units up and down. I have a Honeywell T8411R thermostat and Goodman heat pumps. The upstairs unit was low on refrigerant and was constantly freezing in the high heat and humidity of a NC summer. The blinking icon was telling me the unit had a fault and only the fan was running because the compressor was shut down. A few pounds of coolant fixed my problem. Check cooling tube coming out of the unit for ice, that means it is iced up all the way from inside the house to the outside. Also look inside your exchanger on the inside for ice.
Posted on Dec 27, 2009
Flashing snowflake
The flashing snowflake means it is in the cooling mode, but is waiting for itself to 'time out' after a call for cooling. It should be about a 5 minute delay then should come on automatically. At that poing, the flashing snowflake becomes steady.
Try it one more time and set the timer on your smart-phone to ten minutes before you touch it again. If that time elapses and no cooling and it is still flashing there's possibly a problem in the thermostat that will necissitate replacement.
Aug 02, 2014 | Honeywell Heating & Cooling
Honeywell Thermostat RTH110B
It probably has stopped outdoor unit and the blinking is to be done when working anamoni.afto heating and not to bring in cold air flashes the LIGHT as long heated air into the condenser.
Nov 01, 2011 | Honeywell Electronic Programmable...
I have RCS-2HS4E sanyo air conditioner and I cann't change it to hot it is only cool.
the icons are;
snowflake = cool
raindrop = dehumidification
fan-blade = fan
sun = heat
I am assuming that you have it on the snowflake,hope this helps Tim
Apr 27, 2011 | Sanyo Split System Air Conditioner
Hello sir/ma'am the heat (look like a heater) icon is appearing on the thermastat display beneath the temperature. how do i switch it to air and the snowflake icon to blow cool air. thanks for the...
look for the switch ..their should be HEAT-OFF-COOL the switch should be located next to these words ..you may have to remove a cover plate on the thermostat to switch to cool .you can find it ..let me know good luck..
Aug 25, 2010 | Heating & Cooling
I have a sanyo aircon split system and i need to know the icons
the icons are snowflake = cool, raindrop = de humidification, fan blade = fan, sun = heat. hope this helps.
Jun 11, 2009 | Sanyo Split System Air Conditioner
Snowflake blinking and air conditioner won't turn on.
If it is blinking it is in a 5 minute time delay.
It should settle to a steady snowflake after 5 minutes and come on normally.
May 21, 2009 | Heating & Cooling
Problem understanding Icons on Remote control
The snow flake icon is for your cooling, the sun icon is for heating, please rate this as it will help us if this was helpful to you, thanks,
mr.grzz
Jan 23, 2009 | Continental CE-AC75271 Ductless Mini Split...
Re: 1998 Mitsubishi Diamante Air Conditioner problem
check the refrigerant it might have 2 be recharged
Aug 18, 2008 | 2002 Mitsubishi Galant
Snowflake blinking in one zone
i saw that my snowflake was blinking while the unit was in the 5 minute lock out state (after power up), but went to steady after that.
Jun 14, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
7,667 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
