Question about Sony Ericsson W380i Cellular Phone
Display on front cover is not working - Sony Ericsson W380i Cellular Phone
    Sergeant:
  • 151 Answers
For this problem, first, try to reprogram the phone on the sony ericsson website if the problem still persist the Flex/Ribbon might be broken
Hope this Help
Thanks
Byron
Posted on Oct 04, 2009
  • 438 Answers
Change the display..no other option!!
Posted on Sep 26, 2009
Close side cover error tray
You see front cover switch if front cover knob not touch then this messege appear OR check power card & front cover connection
Nov 06, 2013 | Toshiba e-Studio 350 Copier
How to remove the screen from the y510
The thin plastic 'frame' in the front of the LCD screen, is the Display Bezel.
Goes by many names. Display Bezel is used by HP.
Display Mask, LCD Bezel, LCD Panel Bezel, and LCD Front Bezel, are a few other examples.
Lenovo/IBM uses LCD Front Bezel.
Lenovo doesn't show an HMM for the IdeaPad's, other than for the S9e series, and S10e series, (Notebook), plus the A1-07 series. (Tablet)
(Hardware Maintenance Manual)
http://support.lenovo.com/en_US/SupportSearchResults.page?searchText=ideapad+hmm
(An HMM is a Service Manual)
I also see there are no guides posted by users.
Therefore we'll have to 'wing it', using my years of experience with repairing laptops, and you as the tech.
1) Do you see any screw covers on the LCD Front Bezel?
May not be the usual synthetic rubber covers. May be plastic, and the same plastic, and color as the LCD Front Bezel.
Example,
http://www.insidemylaptop.com/replace-broken-lcd-screen-lenovo-x60s-laptop/
Scroll down to the photos in Steps 1 and 2.
Also note the 'seals' on the side of the Display Assembly, shown in Step 2 photo.
We'll start with this.
2) Haven't worked on a Y510, and perusing the internet; it seems no one has found a solution, for removing the LCD Front Bezel off of an IdeaPad Y510.
{ ALL power removed before beginning. Remove the AC adapter
(Charger), and Battery }
3)
A) There is no sticky double-sided tape holding it on.
B) Can't simply 'pop' it off, as with other Display Bezels, that do not use Philips head screws to hold it on.
[ For all Display Bezels, (Other than this baby, perhaps), there are locking tabs on the outside edges of the Display Bezel.
These match up to snap locks, on the inside edge of the Display Cover. (Top cover of laptop)
When the Display Bezel is removed, the locks snap loose ]
C) I suggest remove the screws which hold the Display Assembly to the laptop, and see if at the bottom of the Display Assembly, there are screw covers, or just screws, to remove.
If there are, and no other screw covers/screws to remove, the LCD Front Bezel should pop off.
This is what I mean by pop off,
http://www.insidemylaptop.com/replace-screen-on-lenovo-g560-laptop/
Step 2 and 3.
{ The laptop is made by Wistron. (Philippines) One of the three major laptop manufacturers, that makes laptops for ALL laptop brand manufacturers.
Such as Acer, Compaq, HP, Lenovo, Toshiba, Asus, you name it }
Post back in a Comment.
Regards,
joecoolvette
May 06, 2012 | Lenovo IdeaPad Y510 Notebook
My printer says drum troubleshooting contact guide manual and maintence I did eveything but still not working
If the display shows drum error you can try cleaning it by following the steps below:
1. Open the front cover. 2. Pull the drum (black) and toner (gray) towards you, put a little force on it. 3. Remove the toner by holding down the tab on the side of the drum, then pull the toner out. 4. Use a dry lint-free cloth to clean the roller inside the drum unit. Make sure to remove any excess toner from it. 5. Put the toner back to the drum, make sure that it clicks, Reinstall the drum and toner back to the machine, 6. Close the cover.
If the display still shows drum error, go ahead and do the drum reset.
1. Open the front cover 2. Press the Options button on the control panel 3. The display should show "Replace Drum - 1. Yes 2. No 4. Press 1 to reset the drum count 5. Close front cover. The display should show the date & time
If still it shows drum error, The drum unit needs to be replace. After replacing the drum unit, do the drum reset again,
Hope this helps.
May 08, 2011 | Brother MFC 7420 All-In-One Laser Printer
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
Front display controls don't work
Sounds like the same problem I had with mine. I had to call and get an RMA number and they replaced the key pad, lcd display, and main board. This repair was covered under warranty. (Under 3 years old) They had it repaired and returned in about a week.
Sep 05, 2009 | Ecoquest Fresh Air Air Purifier
Front display stays dark after boot sequence
you must forget to re install the magnetic piece which located in the lower left corner of the lcd frame cover try to check it
Jun 18, 2009 | Nokia E90 Cell Phone (Unlocked) - Black
Replaced Drum still says "Replace Drum Soon". How do I reset on a Brother 7420?
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
May 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Front cover display light
Check your settings. You might have the back light display as always on. If that dont work then try resting the phone.
Apr 04, 2008 | Motorola Mobility RAZR V3
Cover display not tern on
fix your front panel, the display might be broken. try to use the phone from the inside panel. if it works, do what i tell you.
good luck
Feb 15, 2008 | Nokia 9500 Communicator
How do I reset the Change Drum Soon on the display?
All you should have to do is: -replace the old drum with the new replacement. -with the front door open press the Clear/Back button -press the number 1 button and when ?accepted? appears on the LCD close the front cover. That should do it. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Sony Ericsson W380i Cellular Phone Logo
126 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
