Question about Home
American Standard Hamilton Toilet Leaking
The flapper on our American Standard Hamilton toilet does not seem to seal properly. We have 2 units doing the same thing. What is the best repair here? We have replaced with factory parts but it still seems to leak.
  • 54 Answers
You have installed the parts improperly. You must have 3/8 of an inch slack in the chain from the flapper to the handle when flapper is closed.
Posted on Sep 26, 2009
New toilet 540 fluidmaster water in tank keeps topping off every half hour
The problem may be the flapper that seals between the tank and bowl is leaking or the overflow pipe may have a crack in it. I wouled replace the flapper first and check the overflow pipe for cracks.
Hope this helps.
Bob
Oct 08, 2014 | American Standard Home
American standard caded 3 leaking water from tank into toilet and occasionally running every 5 minutes. is this a flapper problem (it seems well seated) or could it be leaking elswhere?
It could be a bad seat around the flapper or the flapper itself. Replace flapper with one designed for the Cadet. Check water level and see it doesn't flow above the overflow tube. if it is above the tube lower the float ball by turning the screw at top of ball.
May 03, 2012 | American Standard Cadet 3 Right Height...
Toilet flushes intermittently by itself.Water leaking into bowl.flapper and float valve seem to be okay.This is a hamilton 2092.
Check the fill valve. it may have a bad seal inside or some trash in the water supply (iron or calcium deposits) may have clogged it. Do you hear water running when it's not flushing?
May 27, 2011 | American Standard Home
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
My American Standard low water consumption toilet is leaking water. It is not the flapper, as the water level drops below the flapper seat. How do I fix it? I'm not sure of the model, but the tank is...
Did you try calling or emailing the parts dept. at american standard? I am not sure if they just sell the gasket. American standard parts are certainly different from most toilets. I looked on ebay, not much for american standard toilets. Were you able to remove the four screws and get the sealer under the gasket.? I will do some more research for you and try to find parts. take care, andy
Feb 17, 2011 | American Standard Toilet Ravenna 2646.016...
My Crane toilet is slowly leaking into the bowl. It is not the flapper (which I replaced) and doesn't seem to be from high water pressure. Could it be the seal?
Check your over flow pipe in the tank to see if you need to lower the water level amount in the tank. If thats not it, it could be the seal thats under your flapper between the tank and base. Simple fix just alittle time consuming
Sep 24, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
Installed cadet 3 and every twenty minutes it will run for about three seconds and i know it isn't supposed to do that
EITHER THE FLAPPER IS NOT PROPERLY ADJUSTED OR YOU WILL NEED A NEW FLAPPER. WATER IS SLOWLY LEAKING BETWEEN FLAPPER AND SEAT. AS WATER LEVEL DROPS ,TOILET WILL RUN TO BRING WATER LEVEL BACK TO PROPER HEIGHT.
Jan 06, 2010 | American Standard Cadet 3 Right Height...
Toilets are refilling between flushes
Replace the flappers, and clean around the flapper seat.
Make sure the water level is 1/2 " below the large vertical tube by either bending the float rod down or adjust the skinny silver rod on a Fluidmaster unit.
Dec 12, 2009 | American Standard 2002.014 - Champion4...
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
American standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
Oct 28, 2008 | American Standard 2294.011.020 Afwall...
Home Logo
498 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
