Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
When i turn on TV red light is off and I get no sound or picture. I can hear the clicking noise like it is going to start but it doesn't
  • osfn60 Oct 05, 2009
    Thanks for the help!! fortunately it was an easy fix - blown fuse on one of the boards
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your issue ,
Something is shorted causing the shutdown circuits to
be kicking the set off.
Most likely cause the convergence ICs, do a visual of the resistors near the ICs on the large heatsink with fins on it, If any are burnt thats your problem.
they are part # STK392-110
Do a google search to find some.
If none are burnt the ICs may still be bad or the sweep board may be causing the issue.
These aren't easy to fix yourself, a repairman would charge between $300-$650 depending on if its just the ICs or the sweep board
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
Posted on Sep 26, 2009
The tv looks dark and blurry
Posted on Oct 06, 2009
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Hitachi 61UWX10B 61 in | TV will not turn on
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system1.gif. If it finds that there truly is a problem, then the set is shut down and the LED will again flash.
Posted on Jan 30, 2008
SOURCE: Hitachi 60EX388 Rear Porjection TV
i think its the fan that needs to be replaced. or it could be the bulb.
Try to open the bulb assembly unit and take out the bulb and put it back in. If you have an extra bulb, replace it and see if works. This worked for me. The bulb i bought wasnt compatible
Posted on Mar 03, 2008
  • 101 Answers
SOURCE: TV will not turn on. Lights Blink and hear noise
Have you replaced the lamp ? Make sure the door cover is closed good because there is a switch that is made when the door cover is put back on. Also you could have a bad ballast board or bad power unit board. Just a thought...... Hope this is helpful.
Posted on Oct 23, 2009
While we were watching Sony KF60WE610 TV suddenly a loud noise came from the back of the TV,. Sound and picture were gone, and the red light started blinking. We waited 2 minutes and turn on the TV . Sound...
Tv now,have a LED light indication "LAMP" on the frame are blinking or flashing.Metallic sound are clicking noises?Yes,sound like the board that call the Ballast board it is dead.This Ballast board only job are to ignite the tv projection lamp only.U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.The tv projection lamp might have to be replacement change too,because,when the Ballast board has died and exploded the voltages and current high voltages could have more than the tv projection lamp now could take.
Jul 21, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
No picture or sound
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is XL2100 you can find it here:http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173 .Have a blessed one!
May 03, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Telly on but no sound orpicture
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173 .Have a blessed one!
Apr 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Dec 17, 2007 | LG 42PX4DR 42 in. Plasma TV
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
88 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
