Question about Car Audio & Video
No code for radio ford puma 1.7
Battery died and now my radio is asking for a code which i dont have
  • Richard Klein
    Richard Klein May 11, 2010
    What brand is the radio?
  • Car Audio & ... Master
  • 4,869 Answers
The radio will have to be removed from the car in order to find the SERIAL NUMBER, usually found on a label on the casing....and it should begin with M****** or V or L or C
POST A NEW QUESTION
quoting this Serial Number and your code will be calculated for you.
Here is a video showing how to remove your radio from the dashboard. A pair of extractors are required (available from Ebay , Halfords ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
http://www.fitaudio.com/videos/din_keys_guide/video_din_size.html
Posted on Sep 26, 2009
Does anyone know the radio code for ford Mondeo? Serial number: M118 296. Thanks
Ford Radio Code ' Get It For Free - YouTube
? 1:57
https://www.youtube.com/watch?v=0KfNMuFFWpw
May 22, 2014 - Uploaded by ayman ayman
http://www.carradiodecoder.com/2012/01/ford-radio-code.html ... Tutorial how to unlock your Ford radio code ...
FREE - Ford Radio Decode Unlock KeyCode (M SERIES ...
? 0:47
https://www.youtube.com/watch?v=1qDHmnQQSoA
Jan 21, 2014 - Uploaded by Ahmet Deveci
... at your local Ford dealer, get your FREE Ford Escort, Puma, KA, Mondeo, Focus, Cougar, etc radio ...
Ford - Radio Code
Dec 15, 2015 | Ford Cars & Trucks
Tip
How to change a heater control unit/heater control ford puma
Ford Puma
What you will need:-
1.Phillips Screw Driver
2.Depending on what stereo system you have, stereo removal keys.
REMOVAL AND INSTALLATION
Climate Control Assembly/heater control unit/
Removal
1. Standard preparatory measures
Make a note of the radio keycode.
Make a note of the preset radio stations.
CAUTION:
Disconnect the battery negative lead.
2. Remove the radio.
3. Note:The control unit for the heating/air conditioning system, all operating knobs and the air distribution operating switch make up one assembly.
Remove the bezel/control unit.
1 Remove the screws on the top of the unit
2 Unclip the clips either side of the unit
Pull the bezel/unit forwards.
Disconnect the plug.
4. Unclip the air distribution shaft.
5. Remove the heater/air conditioning module and the fan operating switch.
Installation
1. Refit the components in the reverse order.
2. Install the radio.
3. Connect the battery ground lead.
Enter the radio keycode.
Reprogramme the preset radio stations.
Reset the clock.
Carry out a road test to enable the PCM to collect data.
4. Check that the heater/air conditioning operates properly.
on Jan 31, 2010 | Ford Focus Cars & Trucks
Radio code for w reg ford puma serial number M017631
I am sorry but we do not have access to these security codes. What use would they be if you could easily get them off the Internet?? Hmmm
Sep 10, 2012 | Cars & Trucks
I need the code for my radio for my ford puma my serial number is mo11507
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Ford servicecentre and get them to enter this code for you.
Aug 02, 2012 | Car Audio & Video
Please help, My battery went flat & now I've lost my Code for My stereo. Ford Puma 2001 Radio 6000 RDS M003714
get in touch with a ford dealership with your chassis number and they should be able to give you the code for your stereo
Jul 26, 2011 | 2001 Ford Focus
Hi my ford puma wont start and there is a code on the dash board test this is 9359 have you any idea what the problem could be many thanks nicky.
Hi
this is often a flag for a low battery although the code means ACC system failure or bad circuit for some reason when the battery gets low or is in cold weather this code appears. Firstly do you know the code for your radio ? if so then great make a note of that and then disconnect the battery, leave it off for about 1 hour if possible and this will reset the cars ECU. You will need the radio code as when disconnecting the battery it will ask for one when you reconect it.
This does seem to work 9 out of 10 times but if the code reappears then it could be a genuine fault. My experience with fords is often it's nothing.
Give it a try and get back to me.
Regards
Dan
Jan 09, 2011 | Ford Focus Cars & Trucks
The battery on was disconnected and when it was
u have to contact dealership with your vin number and proof of ownership
Mar 07, 2010 | Car Audio & Video
05 ford focus ghia/security code/touch screen
hi, if your radio code for example is 8156 you push the
no1 button 8 times then
no2 button 1 times then
no3 button 5 times then
no4 button 6 times then hold down the number 6 button for about 5 seconds and the radio code will store automatacly and start up. hope this helps you regards
Feb 09, 2010 | 2005 Ford Focus
Car Audio & Video Logo
399 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
