Question about Thermaltake Liquid Cooling System Water Level Indicator Reservoir - CL-W0009
Silent pc motherboad Asus m2npv mx 940 pin am2 AMD Athlon Want change water cooling or what recommend for silent PC
    Problem Solver:
  • 5 Answers
Really depends on your price-range, and to what extent you are looking for "results", to simply make your PC a 'silent', a less expensive one, (ave.$80USD), should work, such as many "COOLMASTER" ones, I have one of these #201(?), and it has the 5"1/4" drivebay LCD panel, works quite well, keeps my Prescott (read "pres-HOT":) (3.0GHZ), down around 70o (versus ave. of about 120o, that ran for about $90 a year ago.
On the other hand, you could Never go wrong with a 'full-blown' "KOOLANCE" system/case. . such as "external water pump & container", although, these range in the 100'sUSD, many time $500+. .
Either way, Water Cooling, IMHO, is the best. .
Keep in mind that a lot of PC's 'noise' actually comes from the Hardrives, although, depending upon your case/setup, this may or may not bother you.
Also, a Good "Sound Dampening" case, or even just the "sound dampening "harddrive covers" work well.. try a Google search for MANY reviews, and product info; simply use;
"water cooling cpu", is a great start.
Let me know if there is anything else about these that you may be wondering, I have had mine running "practically" 95% of the time over an entire 2 years, only requiring a "refill" of coolant about* every 6 months or so. . Evaporation is slightly due to the extreme heat in the room in which my PC is located also tho.
You may also find many opinions on using TEC (Thermal Electric Cooling" devices, enabling you to actually Drop the CPU's to Sub-Zero temps.. but that is usually only preferred tby the 'extreme' Overclockers'. .at any rate.. Good Luck!
Posted on Dec 18, 2007
Upgrade CPU on Matsonic MS8147C+
Unfortunately I think the Athlon XP is a 462 pin package and the MS8147C+ has a SocketA/Socket 462 socket for the CPU. The Athlon 64 3800+ is a 940 pin package and requires a AM2 socket, so this CPU will not physically fit.
Jan 18, 2014 | Matsonic MS8147C+ (N82E16813184008)...
M2NPV-VM - Fastest Processor?
If ASUS says that is the fastest that will work on the board, then they should know. Incidentally processors don't run at 95 volts although some run at a power consumption of 95 watts. Besides there is not a faster AM2 CPU than the one you mention.
Jan 30, 2013 | ASUSTeK COMPUTER Asus M2npv-vm Motherboard...
What can i use processor in this motherboard can i use 1.8 mhz
Processor speed 1.8 MHz is not the parameter for using this kind of motherboard. Upgrading or replacing CPU on motherboard is based on the socket CPU, and your motherboad support AMD® Socket AM2 Athlon 64 X2 / Athlon 64 FX / Athlon 64/ Sempron....
Aug 06, 2011 | ASUS M2N-MX Motherboard
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
What pcu
Both the K9AGM2-F/L and the               K9AGM2-FIH model both take the (AMD) AM2 socket CPU just like is stated on the box.
http://global.msi.com.tw/index.php?func=searchresult&keywords=+K9AGM2
Feb 08, 2009 | MSI K9AGM2-FIH - Motherboard - micro ATX -...
DDR2 with ASUS A8V-MX motherboard
This motherboard supports AMD 939 pin Athlon 64 FX/ Athlon 64 processors with 1MB, 512 KB L2 cache which is based on 64 bit architecture. It features 1600 MT/s HyperTransport Bus, dual-channel unbuffered DDR400 memory support and AMD cooling Technology. So you should be able to use the RAM as long as it falls into the above specs. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | ASUS A8V-MX Motherboard
ACER 180 (AMD 64 3800+) upgrade
any amd 64 will work. bios should be ok if you stay with just the amd 64 if this is a aspire t180 then you might want to go to a 64x2 which you will have to flash the bios. hope this helps
roduct
Aspire T180 Language
English Model
Aspire T180 Specifications Specifications
Processor
AMD AM2 Athlon 64 x 2 or Athlon 64 or Sempron (940 pin)
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Thermaltake Liquid Cooling System Water Level Indicator Reservoir - CL-W0009 Logo
206 people viewed this question
Top Thermaltake Computers & Internet Experts
Martin Clarke
Martin Clarke
Lawrence Oravetz
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
