Question about Samsung LN-T5271F 52 in. LCD Television
My Samsung TV power indicator light cycles on and off.
My Samsung TV model LN-T5271F cycles on and off, and that's all it does. I tried pulling the plug on it, and that it will return to normal, but it keeps cycling on and off. I read if you change the capacitors it will fix the problem. Is this true, if so does any body have the part numbers for them.
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your issue ,
Your power supply is the problem, a repairman will charge between $250-$450
depending on if they repair or replace the power supply
Seems you know about this already, they are either 1000uf at 16volts radial caps or 2200uf
open the set and look for bulging caps
here is where you buy new ones
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
Posted on Sep 26, 2009
Where I can get capacitors CM852 & CM853; 2200ufd 25volts from ? I have issue with power cycling (Samsung model LNT5271f )
These should be available from most electronics shops e.g. maplin, or on-line e.g. e-bay. Just search for 2200uF 25V capacitor.
Feb 24, 2011 | Samsung LN-T5271F 52 in. LCD Television
I have a Samsung LCD (LN-T5271F) about 2 years old and lately when I turn it on, it clicks on and off several times before it actually stays and the tv comes onI have a Samsung LCD (LN-T5271F) about 2...
Call Samung customer service, they are doing this repair for free. I had the same problem at 11 months, they replaced the power supply board under warranty. At 2 years I had the exact same problem again and this time they replaced 2 - 50 cent capacitors on the power supply board. It took the repair man less than an hour and he had the replacement capacitors on hand. The original board and the replacement board they gave me had capacitors that were faulty. Hopefully these new capacitors will last. I have to say that I was thinking (no more samsung products for me) but I got excellent customer service and they admit that they had a faulty product and they accepted responsibility.
Apr 26, 2010 | Samsung LN-T5271F 52 in. LCD Television
Samsung TV now takes over 30min to come on
There are a number of Capacitors on the IP/Power supply bd and they have gone bad. Replaced them with the proper Capacitance as the old ones are BUT get the 35 volt Caps. Going from 10v to 35v will fix this problem.
Apr 14, 2010 | Samsung LN-T5271F 52 in. LCD Television
Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Sep 28, 2009 | Samsung LN-T5271F 52 in. LCD Television
Power on problem
replace +5vdc out capacitor two 2200uF 10v and 47uF50v with top quality capacitor. u save $400. other than this samsung is OK
Jun 27, 2009 | Samsung LN-T5271F 52 in. LCD Television
Samsung power-up problem
two 2200uF capacitor, two 1000uF capacitors on powersupply board.
Replace it! you will save $300.
Jun 19, 2009 | Samsung LN-T5271F 52 in. LCD Television
Samsung LN-T5271F 52 in. LCD Television Logo
1,208 people viewed this question
Henry  Thomas
Henry Thomas
