Question about Dell Latitude D600 Notebook
D600 Service Pack 1 CD Copy
I was wondering if I can get a copy of SP1, I have misplaced mine. If anyone has a copy that will be really helpful.
  • spacexpo Dec 21, 2007
    I have tried that before, but certain hardware (i.e. internal wireless card) are not compatible. Do I need SP1 D600 original CD?
  • 56 Answers
just download SP1...
Posted on Dec 17, 2007
Windows does not giev me updates that I need to instal servicepack 1 and 2 needed to instal IE 9 or windows 7.
service pack 1 and 2 are old school, they are fading away unfairly
you need a copy xp sp1 ebay has it xp sp2 ebay has it once you have these service packs, unzip them load them, updates will start
for service pack 3 customize because you will not use everything
good luck
Dec 02, 2013 | Other NEW Fujitsu Amilo LA 1703 LA1703...
I am trying to copy Windows 7 SP1 either as the simple service pack or Windows 7 Ultimate with SP1 but for both files I receive the same Toshiba Disc Creator error message 310981-34-00000000. I have...
That will only work with the Toshiba Disk Creator software and if anyone has made those already it won't work at all. Those are both copy protested files that use a special format to keep people from making copies of them. The back up files stored on the hard drive for restore purposes only work with the disk creator software that comes with Toshiba computers and that software has a hard coded counter that won't let you make more than 1 copy. If your using the correct software and still have the problem it maybe the DVD's your using. Make sure you have DVD's that are a compatible format with your DVD writer function. You may need the DVD -R instead of the +R dvd's you indicated you are using.
Feb 18, 2011 | Computers & Internet
How to create a bootable Windows XP SP1 CD
Using nero .
Step 1
Create 3 folders - C:\WINXPSP1, C:\SP1106 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP1
Step 3
You will have to download the SP1 Update, which is 133MB.
Rename the Service Pack file to XP-SP1.EXE
Extract the Service Pack from the Run Dialog using the command:
C:\XP-SP1.EXE -U -X:C:\SP1106
Step 4
Open Start/Run... and type the command:
C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP1 contains: Windows XP SP1
How to Create a Windows XP SP1 CD Bootable
Step 1
( no download manager !! )
Extract file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.
Select File > New... from the menu.
1.) Select CD-ROM (Boot)
2.) Select Image file from Source of boot image data
3.) Set Kind of emulation: to No Emulation
4.) Set Load segment of sectors (hex!): to 07C0
5.) Set Number of loaded sectors: to 4
6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:
Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab
Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)
Set Format to Mode 1
Set Character Set to ISO 9660
Check all Relax ISO Restrictions
Step 5
Click Label Tab
Select ISO9660 from the drop down box.
Enter the Volume Label as WB2PFRE_EN
Enter the System Identifier as WB2PFRE_EN
Enter the Volume Set as WB2PFRE_EN
Enter the Publisher as MICROSOFT CORPORATION
Enter the Data Preparer as MICROSOFT CORPORATION
Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN
* For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab
Check Write
Check Finalize CD (No further writing possible!)
Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP1
Select everything in the folder and drag it to the ISO compilation panel.
Click the Write CD Dialog button.
Oct 11, 2010 | Microsoft Computers & Internet
How i can make a bootable Windows CD for my personal use
Create a temporary working folder at the root (top) of the C: drive called "XPSETUP" (without the quotes). Actually, you can name it anything you want and put it anywhere you like, but for ease of explanation, the remainder of the steps below will assume that you have created the XPSETUP folder in the root of drive C:. This C:\XPSETUP folder will be where you will create the CDROM directory structure for your bootable Windows CD.
Copy the entire C:\I386 to C:\XPSETUP. When you have finished, you will have C:\XPSETUP\I386. Notice that I said "copy", not "move". Do NOT drag and drop the I386 folder into the XPSETUP directory. If you do so, you may end up moving it into the XPSETUP folder (depending on where you created the XPSETUP folder). It is important to work from a copy of the I386 directory so that if you make mistakes, you can simply go back and start all over again. If you move the directory or drag and drop it, and you make a mistake, your mistake will be permanent. So once again, COPY the entire I386 folder to XPSETUP. It may take a while for the copy operation to complete, but it's safer this way.
If you're not sure how to copy, follow the following procedure: Highlight the I386 folder using Windows Explorer. Right-click the folder and select "Copy". Then open the XPSETUP folder. The folder should be empty at the moment. Right click the empty space in the window and click "Paste". A very lengthy copy procedure will take place.
To verify that you have copied the folder and not moved it, return to the top of C: and check that the I386 folder is still there and that the original files in that folder are still there.
Create an ASCII text file with only the word "Windows " (without the quotes and including the final space after the word "Windows") in it, followed by a new line. To do this, open up Notepad. Notepad can be found in your Start menu -> Programs -> Accessories -> Notepad. Type the word "Windows" without the quotes and following my case exactly (that is, "W" is a capital letter and the rest are in small letters). Then type one additional space. Finally, hit the ENTER key. Do not add anything else to this file. Do not change anything - for example, do not type everything in capital letters or anything like that. The contents of the file must be exactly as I said, or Windows setup will issue an error message.
Save the file with the filename "WIN51" (include the quotes so that Notepad will not add a ".txt" extension behind your back) in C:\XPSETUP. Again, the filename's spelling and case must be exactly like mine.
If your PC or laptop originally came with XP Home, make a copy of the file you just created and call it "WIN51IC". If you are using XP Home Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IC" and "WIN51IC.SP1". If you are using XP Home Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IC", "WIN51IC.SP1" and "WIN51IC.SP2". All the copies of the files should be in C:\XPSETUP.
If your PC or laptop originally came with XP Professional, make a copy of the file you just created and call it "WIN51IP". If you are using XP Professional Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IP" and "WIN51IP.SP1". If you are using XP Professional Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IP", "WIN51IP.SP1" and "WIN51IP.SP2". All the copies of the files should be in C:\XPSETUP.
Note carefully what I said above. You may be running XP SP 2 now, but if your PC came with XP SP 1, you should create the files for XP SP 1. There is an exception to this. If your PC or laptop came with XP or XP SP 1, but you want your Windows install CD to install XP SP 2, create the WIN51 files needed for SP 2 and follow the procedure for slipstreaming Windows service pack 2 (SP 2) into the Windows setup CDROM given in the next step.
If your PC or laptop came originally with XP or XP SP 1 (service pack 1) but you want your Windows setup disk to install XP SP 2, do the following. Otherwise, skip to the next step.
Note that even if you have since updated your computer to SP 2, you will still need to do this step if you want your setup CD to install Windows XP Service Pack 2. The reason is that updating your running Windows system does not automatically update the I386 directory. Your I386 directory still contains the Windows setup files belonging to whatever version of Windows you had when you first bought your PC/laptop.
Download Windows XP service pack 2 from Save it anywhere you like except in the C:\XPSETUP folder. For the purpose of this tutorial, I will assume you saved it as C:\XPSP2.EXE, that is, in the root folder with the filename "XPSP2.EXE".
Important: if you did not configure Windows to show you the full filename you should probably do so before changing the name of the file. Otherwise, you may be inadvertently saving the file as "XPSP2.EXE.EXE" without your knowing. (That is, you see the filename as "XPSP2.EXE" in Windows Explorer but it's actually "XPSP2.EXE.EXE".)
You will need to update the C:\XPSETUP\I386 folder to contain the updated SP 2 files. As a side benefit, the service pack 2 updater will also create a few files (including setup.exe) in the C:\XPSETUP folder. This process of integrating the service pack files into the original XP or XP SP 1 is known as "slipstreaming".
To slipstream SP 2, first open up a command prompt. To do this, click the Start menu, select the Run menu item, and enter the words "cmd". Click the OK button. A black command prompt window will open.
Enter the following line into the window and press the ENTER key.
C:\XPSP2.EXE /integrate:C:\XPSETUP
After the program finishes, you can close the command prompt window. If you look into your XPSETUP folder, you will notice a few new files there.
At this point, the C:\XPSETUP directory contains all the files that will be copied to your Windows Setup CDROM. Don't worry if the directory does not contain files like "setup.exe" which you see on the retail CDROMs. You won't need it for a fresh install from the bootable CDROM. Note: You will only have "setup.exe" if you had to slipstream Service Pack 2 as mentioned earlier. The Service Pack 2 slipstreamer creates setup.exe for you.
Now open the file that you downloaded earlier. Simply doubleclicking it in Windows explorer should do the trick. Go into the cds directory and into wxphome (or wxppro; it doesn't matter which) directory, followed by the files directory. Drag the "w2ksect.bin" file into C:\ (the root directory/folder of drive C:). Don't get creative and place it in some other directory. If you do that, ImgBurn will not be able to find c:\w2ksect.bin later.
You could do all that OR simply download an XP LIVE DVD.. This will  bootup from DVD and work without using/installing to the Hard Drive.
here is the torrent DL link No torrent?  Here >
DL and install.. then click on torrent link and it will DL.
here is a link how to make it.
Feb 01, 2010 | Microsoft Windows XP Professional SP2
Vista Service Pack 1 Crack Activation
This is not a thing to discuss here :P There are working cracks and try to find those.
May 09, 2009 | HP Pavilion dv4000 Notebook
Product key fow vista service pack 1
Did you buy the product or get a bootleg? Microsoft is catching on to bootleg copies. When you activate your copy, they do a hardware check to make sure your using it on the same computer everytime.
Jan 16, 2009 | Microsoft Windows Vista Home Premium with...
Which Service Pack is included with my Win XP Home Edition Version 2002?
Windows XP Home 2002 is Service Pack 1 only:
Buy a newer version.
Do not forget to rate the solution.
Many thanks.
Aug 29, 2008 | Microsoft Windows Xp Home Edition Sp2...
Sata with xp>>>>>>
check your copy of xp cd if it is bootable or try and go to bios setup and enable the first boot to be cd-rom, atapi cd-rom. But it is really obvious that your xp copy is not bootable.just try out the procedure above. good luck
May 24, 2008 | Intel Motherboard
Dell Latitude D600 Notebook Logo
Alun Cox
