Question about HP Compaq Presario V2000 Notebook
Problem on cd drive
It's 2 days before everything is all right.But now i can not see my cd drive icon in my computer and the cdrom was not blinking or reading.
please sir
  • 56 Answers
If that case your cdrom drive not see...just simply you just open your pc disconnect the connection of cdrom drive and after you connection again better..i think your connection will loss contack the socket of the cdrom that why that power not to blink...
Posted on Dec 17, 2007
Cd rom drive door keeps opening up when in, it won't start cd
Try to this. Start - Right Click My Computer - Properties - Hardware - Device
Manager - CDROM - Properties - Disable. See if it Stops then enable it again.
Look at cdrom button it might obstructed or pressed in, try pulling and pressing. Or it could be a program/driver problem. Try restoring your pc the day before it happen.
Sep 14, 2011 | E-Machines emachines (emachinees) CD-ROM...
Create a Shortcut or Hotkey to Eject the CD/DVD Drive
Create a Shortcut to Eject the CD/DVD Drive
Right-click on the desktop or elsewhere and choose New \ Shortcut.
In the location box, put the full path to the nircmd.exe file that you downloaded, and append the "cdrom open" command to the end of it, adjusting the drive letter to match your disc drive:
"C:\path\to\nircmd.exe" cdrom open D:
Note the location of the quotes.. if you are using a path with spaces in it, you need to make sure the quotes are only around the path to the executable, and the arguments should be placed after the quote.
Give the shortcut a meaningful name, like Eject CD or something like that, and you'll have a new icon (read below on how to use the cd-rom icon as shown)
Create a Shortcut to Close the CD/DVD Drive
You can follow the same exact instructions as above, but instead of "cdrom open" just substitute "cdrom close".
Assign a Hotkey to the Shortcut
Now that we have a shortcut, we can assign a hotkey to the shortcut by right-clicking on the icon and choosing Properties. On the Shortcut tab you'll see a place to assign the Shortcut key:
on Apr 29, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
My dvd c drive is not workin wat can do for downloadin n how to install dvd cd-rw drive
Go to my computer and make sure that the combo drive is showing up. If it is then you may have to set the region to region 1 if you live in the US this is a common issue with most drives being installed. Make sure that the region is set. Then you will be able to use it. I had the same problem until I set the region on it then it worked. How to do this?
Go to My Computer right click go to properties then select devices. Look for your combo drive then right click on it and select region set it to the area that you are in. Windows 7
Go to My Computer right click and go to properties then select device again look for your CDROM devices select the one in question and right click and set the properties look for region set this to region 1 or the area you are in XP.
With all that said and done. If you device is not located power off the computer. Unplug computer from the wall push the power button for about 2-3 seconds then remove the case and unplug the device cable and power plug on the drive only. Now restart the computer again with the CDROM unplugged wait for the computer to settle in then shut it down again. Do the same thing push the power button in again with it unplugged plug in the cable and power plug to the CDROM back in now plug in the computer and restart the computer. You should see a hardware update that is updating your CDROM combo drive showing. I hope this assisted you. John
Feb 28, 2011 | Dell (1000-DVDCDRW) CD-RW/DVD-ROM Combo...
How to open dvd or cd drive acer computer
1. There should be a button in the middle of the CDROM tray, click on it and it will eject the CDROM Tray.
2. Open My Computer> Right click on CD/DVDROM icon & click eject.
Mar 12, 2010 | Acer Aspire 5610-4648 Notebook
Cdrw/dvdrw won't recognize or read cd. I replace original cdrom and it works fine. Worked when first installed?!?!
Since you've already replaced the cdrom, the next thing you need to do is delete this registry files,..
This fix came from microsoft if your optical drive can't read or recognize discs,.
if your using windows vista or windows 7, click on the start button then in the start search box type in REGEDIT,
If your using windows xp click on the run icon then
After that look for this,
There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
In the right pane, right-click UpperFilters, and then click Delete.
Click Yes to confirm the removal of the UpperFilters registry entry.
In the right pane, right-click LowerFilters, and then click Delete.
Click Yes to confirm the removal of the LowerFilters registry entry.
Then after that go to device manager, look for your cdrom device, you can easily find it,.
If your using windows vista or seven just right click
on the computer icon then properties,
then on the top right corner of the window you will see device manager, click it, then look for the
cdrom, click the cdrom icon, a drop down box will come up, click on the item that came up, then right click it, click on uninstall,
Do the same thing in xp, but to get to device manager right click on my computer, then do the same process.
after that restart the computer and it will automatically restart.
If this one still doesn't work, update the firmware of your
cd rom which you can get from dell's support website, after that if all else fails,
back all your files and then reinstall the operating system.
Hope this helps!
Feb 15, 2010 | Dell Latitude D505 Notebook
I have a 2gb SanDisk & would like to put my CD music on it to play in the car, is this feasable & if it is how do I go about it?
From your Desktop... Open My Computer.. Then Right Click On The CDROM Icon...
Choose To Explore CD
Press: Control + A (this will highlight all the songs)
Then Either Drag all the songs to the Flash Drive Icon
Right Click On One Of The Highlighted Songs, and Choose Move... then direct it to Your Flash Drive...
Dec 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
Missing cdrom drive
The triggers determining the slave was set to master with the CD rom drive as I had two master drives...kind've stupid. Everything is now working properly!
Dec 30, 2008 | Memorex (278010300003) Internal DVD Drive
Hi there
Thanks for posting your problem on fixya
IT seems that problem your cdrom drivers please go to device manager >> right click on my computer then click on hardware then click on device manager double click to cdrom and uninstall cdrom drivers then reboot and reinstall cdrom drivers. Your cdrom working fine
Don't forget to vote me
Sep 26, 2008 | E-Machines eMachines Desktop PC
Missing cdrom drive
Is the LED of your CD ROM blinking? If yes then go to device manager by right clicking the My Computer icon and then click the Properties command. In the Properties window select the Hardware tab and then click the device manager. Is the CD ROM entery there! yes> right click and enable the device. If no then reformat your hard disc and reinstall.
In case your CD ROM's LED is not blinking (Rarest case) then simply check all the cables connected to it, atleast the power cable. if it is still not working, your CD ROM got damaged and there is a time to change it.
Feb 04, 2008 | Computers & Internet
Connection Problems
If you have other Optical Drive in your computer like a CDwriter then installed it where that LG 52x CDROM drive. Observe if the same problem occur after 2 or 3 hours. Try connecting the CDROM drive to the IDE ports (Secondary IDE port) like setting its jumper to Master. Ensure that the connection to its power supply is firm. Change the setting of your POWER OPTIONS which is under the CONTROL PANEL and change the setting for TURN-OFF HARD DISK to NEVER.
Apr 08, 2007 | LG (GCR-8523BB) Internal 52x CD-ROM Drive
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
