Question about Kenmore 63942 Dryer
The dryer will not turn on. Timer is ticking I think it may be the start button
  • Kenmore Master
  • 7,482 Answers
Could be the start button, but also could be a broken drum belt or the belt maybe has slipped off the motor pulley or idle arm pulley. Also could be a bad motor. Check to see if the motor is turning first and the belt is on properly.
Posted on Sep 26, 2009
My Malley 1050S dryer: timer is ticking away but the machine is doing nothing : (
I agree, always cut your losses, dryers are not that expensive. When my home aids break I LOOK To buy new ones now. I figure that once they start breaking they will carry on doing so
Jul 17, 2015 | Dryers
Dryer doesn't start
Actually, it's probably the switch under the button meeting its demise.
Jan 14, 2018 | Whirlpool Dryers
Dryer will not start but timer ticking
If the start button is an "ON - OFF" button (meaning, you can turn the dryer off manually instead of resetting timer in order to switch it off), try turning the dryer ON...then switch it back to "OFF".
Hopefully the dryer will continue, and the thermostat will kick in.
Dec 01, 2013 | Dryers
My dryer wont start when I push the start button. You can hear the tick, tick when turn the timer on. Is it the start button or thermal fuse?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 22, 2010 | Dryers
The dryer won't start. the timer is ticking, but ...
check the door swich see if it is catching,,,,the switch is on the inner part of the door frame,,,,if that dose not work look into the thermofuse ....if dryer making a nose atattempted start up you may need a motor,,,,,,,,,www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
My kenmore dryer just stopped working. the timer
the timer has internal cog teeth with works with an ecentric cam to keep the timer operating. the cam is working if ticking although a tooth appears to be broken keeping the timer to advance on its own
Mar 13, 2010 | Kenmore 63942 Dryer
Won't start
IF ELECTRIC CHECK 220 VOLTS @PLUG MAKE SURE DOOR SWITCH IS FULLY ENGAGED
Nov 28, 2008 | Kenmore 73952 Gas Dryer
Kenmore 63942 Dryer Logo
76 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
